Print at Feb 26, 2020, 6:22:24 AM
Posted by Puybaret at May 7, 2015, 6:47:25 PM
Re: Sweet Home 3D 5.0
Thanks for your feedback smile
Could that plug-in be integrated in the main program?
It's not what I plan at the moment.
Edition > Paste
Probably this is franglais?
No, I don't think so biggrin
It lets you copy the color/texture of a given copied object on others selected objects of the same kind without displaying again their modification dialog. It can be also used to keep in memory the color/texture of a room for example, when the quickest way to recompute a room is to delete it then recreate it with a double-click. Note that you can copy the style of a room only on rooms, copy the style of a wall only on walls,... and there should be only one object in the clipboard to enable this new menu item.
