Print at Sep 20, 2019 10:07:41 PM
Posted by hansmex at Jun 4, 2015 10:06:17 AM
Re: Sweet Home 3D 5.0
Emmanuel,
Problem of copying walls to levels is solved. After unselecting the walls, they now copy correctly on every level. Thanks.
Small wish: would it be possible that the O= sign to indicate same elevation levels, could also serve as a visible/invisible switch? Standard symbol = visible. Reversed symbol (as in reversed colours) = invisible? So, the switch is incorporated into the tab.
Thanks once again.
