Print at Jun 2, 2020, 1:08:45 PM
Posted by Puybaret at Jan 30, 2018, 11:08:07 AM
If you want to change the visible parts of a given model, you should use different MTL files changing the transparency factor in d lines (d 0 being fully transparent and d 1 fully opaque). As the MTL file used by an OBJ file must be cited in its mtllib line, you won't have any other choice that creating different OBJ files.
But it's not a problem to have different pieces citing the same value in their model...# property and a different value in their planIcon...# or doorOrWindowSash....# properties. There was a bug in the Furniture Library Editor some time ago about this but it was fixed in version 1.20.
By the way, here's a version 1.22 of the editor with IDs if needed. I promise the choice of the columns editable in the editor will end up in preferences one day wink
