Print at Feb 28, 2020, 8:38:04 AM
Posted by C_Valanc at Jun 12, 2009, 10:41:00 AM
Re: SweetHome3d shut down after some seconds
I had the same problem after the version 1.4 (the first as I used), with 1.6 and 1.8 in the default directory. Same problem when I install the new version after I had uninstalled the previous version. Only the versions .jar was working.
I has just to install the versions 1.5, 1.6, 1.7, 1.8 and 2.0 in different directories.
* the versions 1.6, 1.7 and 1.8 run properly, in opposition to my previous tests (an old file not uninstalled ?).
* in these same conditions, the version 2.0 starts and then stops after 2 or 3 s.
