Print at Apr 3, 2020, 1:02:05 AM
Posted by enkonyito at Jan 13, 2020, 3:46:08 PM
Re: YafaRay rendering plug-in
With the YafaRay Blender-Exporter, I was able to find examples of XML scenes using different types of light.
enkonyito, before I investigate your problem, could you try again with this new version fist?
With this version 1.0 Beta 4, the following three problems occur again.
1. No light emitted for arealight.
Example of implementation.
params.put("type", "arealight");
Point3f corner = new Point3f(-100, -100, 100);
Point3f point1 = new Point3f(-100, 100, 100);
Point3f point2 = new Point3f(100, -100, 100);
params.put("corner", corner);
params.put("point1", point1);
params.put("point2", point2);
params.put("from", new float [] {0, 0, 100});
params.put("color", new float [] {
((lightColor >> 16) & 0xFF) * ((this.homeLightColor >> 16) & 0xFF),
((lightColor >> 8) & 0xFF) * ((this.homeLightColor >> 8) & 0xFF),
(lightColor & 0xFF) * (this.homeLightColor & 0xFF), 1});
params.put("power", power);
params.put("samples", 4);
createLight(UUID.randomUUID().toString(), params);
I think it's related to line 84 of the arealight.cc file even for double sided panels.
2. Identifier not taken into account for spherelight and arealight.
To make the sphere or area lights visible, add
params.put("object", id);
returns the error "Invalid object ID given!".
How to find this identifier after the creation of the object (mesh)?
3. SH3D crash for meshlight.
params.put("type", "meshlight");
params.put("double_sided", false);
params.put("light_enabled", true);
params.put("object", 1);
These portions of code are implemented in the exportLightSource method of the YafarayRenderer class.
