Print at Jul 12, 2020, 5:14:36 PM
Posted by hansmex at Nov 14, 2010, 9:27:47 PM
Re: my wishes :-)
Macfrog,
1 - Which check mark? Depending on the quality setting there is one, or there are three check marks. And what should it enable/disable?
2 - Ceilings are switched ON and OFF for each room individually. If you want to switch on all rooms at the same time, just select them all and change them all using Modify rooms.
3 - If your ceiling is visible, sunlight is blocked. If your ceiling is invisible, sunlight can enter. Seems very logical, and I don't think we should change that.
4 - Select a wall, then click Plan --> Split wall and the wall is split in two equal parts. Change the coordinates of one part to move the split to the exact location you want it.
Maybe it's a good idea to familiarize yourself with the program, and read the manuals, before asking "new" features?
