Print at Dec 11, 2019 3:43:20 AM
Posts: 57   Pages: 6   [ Previous Page | 1 2 3 4 5 6 | Next Page ]
Posted by Puybaret at Feb 12, 2010 10:13:35 PM
Re: Sweet Home 3D 2.3
Hans, I didn't change the way the program is launched. sad
What I don't understand is whether your desktop icon is wrong or the program doesn't work anymore.
How many times did you try to launch the new beta?
Can you still launch the beta from theJNLP link?
I tested again the 6 arrows and they work in both modes.
The left, right, up and down navigation arrows have the same effect as the matching keys of the keyboard, whereas the two small up and down arrows at center have the same effect as the page up and page down keys.
I hope you'll be able to launch the program again.
Posted by hansmex at Feb 13, 2010 1:58:50 AM
Emmanuel:
Well, I did a big update for Ubuntu, so I guess that causes the problem.
Yes, I can start SH3D by clicking the download link; it checks and finds the already downloaded file and starts it.
I restarted my computer to see if the icon would start the program, but without success.
If I open a terminal and copy-paste the "text" from the icon, the program starts without a problem.
/usr/lib/jvm/java-6-sun-1.6.0.16/jre/bin/javaws -localfile -offline /home/hans/.java/deployment/cache/6.0/14/81813ce-3dc3e262
I can't reproduce the little problem with the new arrows, so maybe it was just a quirk.
Posted by Puybaret at Feb 13, 2010 8:14:57 AM
I'm glad to read it still works. smile
I guess this dialog is just a new security warning added to Ubuntu. I hope it won't prevent other users from using Sweet Home 3D.
Posted by hansmex at Feb 14, 2010 10:57:53 AM
Emmanuel:
In v2.3.b7 I cannot modify my imported models anymore.
Of course there could be several reasons for this behaviour.
- because I start the program from the online jnlp-link?
- because I use Ubuntu?
- because it's a bug?
Posted by Puybaret at Feb 14, 2010 2:08:00 PM
This is a bug and I fixed it in version 2.3 Beta 8.
Thank you for your help. smile
Posted by hansmex at Feb 14, 2010 5:30:45 PM
Hello,
When using Ubuntu 10.04 you will have to change the program permissions in order to be able to start SH3D from the desktop icon.
Right-click the text icon on the desktop and select PROPERTIES. A window opens as seen below:
Click the PERMISSIONS tab and make sure to check the box that says "Allow executing file as a program". I also changed the other settings to "Read and write" although I am not sure if that is necessary. Close the window and you'll see that the desktop icon now shows the SH3D logo. Double-clicking the icon now starts the program.
Success.
Posted by hansmex at Feb 15, 2010 3:08:53 PM
Emmanuel:
I made a model of a spiral staircase, using a grouped set of 3 elements to build the steps. Due to some small not-reproducible bug I had to save the model and re-open it. Unfortunately the grouping info is not saved with the rest of the model/scene info.
Is there a chance you could add this?
Posted by Puybaret at Feb 15, 2010 3:43:06 PM
Hans, the grouping info should be saved.
I just tried and it worked for me.
If you find a way to reproduce this bug, don't hesitate to post it to help me fix it. smile
Posted by Puybaret at Feb 16, 2010 8:06:42 AM
I found the bug about the grouping info. In fact the grouping info is lost in memory just after you save your home. So if you save twice a home with a group, the group info will be lost also in the file.
Sorry for this problem, I will be fixed in the next beta version.
Posted by hansmex at Feb 16, 2010 1:51:44 PM
Emmanuel:
Thanks for your dedication and meticulous bug hunting.
Please, don't say sorry for bugs in the program, I guess it's inevitable. What counts, is the speed with which they are solved.
Thanks again!!
