Print at Jun 16, 2019 6:06:23 AM
Posts: 57   Pages: 6   [ Previous Page | 1 2 3 4 5 6 | Next Page ]
Posted by hansmex at Feb 24, 2010 2:28:21 PM
Re: Sweet Home 3D 2.3
Emmanuel:
After a quirky start with Windows Vista (maybe you have seen my deleted post) everything in v2.3b15 seems to work fine on both my computers.
I'm busy updating the English manual and hope to provide a "serious" first draugth (a beta version) pretty soon.
One suggestion for the menu structure: move Plan -> Export to SVG format to 3D view -> Export to SVG format. It seems more logical to have them together. Or else, maybe, you could create a new menu item called Tools or Extra (as in Windows) where you put all the extra tools together.
Posted by pencilart at Feb 25, 2010 9:49:08 PM
I found a bug (I think).
v2.3b15
When I tried the create photo, the quick one and the one after that worked but the Best and the next to best did not. It (the rendering area) was just black.
Posted by Puybaret at Feb 25, 2010 10:58:11 PM
The.camera was probably in a wall, and with the two best quality renderers, this will make a black image.
Posted by pencilart at Feb 26, 2010 3:45:17 PM
biggrin   Re: Sweet Home 3D 2.3
ok, I'll try that. Thanks for the explanation. :) biggrin
Posted by High.G at Mar 4, 2010 5:09:54 PM
this program is realy good now i can improve my skills in housemaking ^_^
thank u sooo much
Posted by brill at Mar 5, 2010 7:59:15 AM
I just tried to seperate the 3D view on Linux.
The 3D view disappeared form the Main View but there was no separate Windows.
(I'm right now using Ubuntu 9.10 with KDE)
Cheers Brill
Posted by Puybaret at Mar 5, 2010 11:28:20 AM
Would you have any log or stack trace to report, please?
Posted by brill at Mar 5, 2010 8:36:34 PM
Hi Puybaret,
How can I get stack trace from this Java Webstart?
Cheers Brill
Posted by brill at Mar 8, 2010 8:52:32 AM
Hello Puybaret,
here is my Stactrace:
Java Web Start 1.6.0_15
Verwendung der JRE-Version 1.6.0_15-b03 Java HotSpot(TM) Client VM
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: adding a container to a container on a different GraphicsDevice
at java.awt.Component.checkGD(Component.java:1099)
at java.awt.Container.checkGD(Container.java:1105)
at java.awt.Container.addImpl(Container.java:1041)
at javax.swing.JLayeredPane.addImpl(JLayeredPane.java:212)
at java.awt.Container.add(Container.java:927)
at javax.swing.JRootPane.setContentPane(JRootPane.java:608)
at javax.swing.JDialog.setContentPane(JDialog.java:997)
at com.eteks.sweethome3d.swing.HomePane.detachView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.detachView(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane$1.actionPerformed(Unknown Source)
at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:272)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Posted by Puybaret at Mar 8, 2010 10:37:17 AM
Thank you brill for this stack trace. It should help me to fix the bug.
Do you have two screens?
