Print at Aug 11, 2020, 4:19:35 AM
Posted by hansmex at Nov 14, 2010, 9:17:46 PM
How to share images and files
Hello all,
If you want to show off your beautiful design, or if you want to share a file, here is some help on posting.
- Give a meaningful description where it says Post Topic*
- In the window underneath you can write your message.
- If you want to share a picture, click the button Image and paste a link to the picture you want to show in the pop-up window. Use the button Preview to check if the picture appears in your post. Example: http://www.mediafire.com/conv/2f18753d3b69144...a1301b69eec4985df846g.jpg
- If you want to share a file, click the button http:// and paste a link to the file in the pop-up window. The link to your file will appear in your post, underlined and in light blue. The file itself is not included in the post, so choose a service that does not delete your file after a week. If you share a SH3D file, be sure to use only models that can be redistributed (models available on sweethome3d.com can be redistributed but not the ones coming from Trimble Warehouse).
- An excellent place to store all pictures and files that you want to share is www.mediafire.com . It's free, offers 5 Gb of storage and has a good and easy user interface. If you want an image hosted at media fire.com to appear in the forum, you should follow these steps:
1 - Open the image hosted at media fire.com
2 - Right-click on the image and select Share
3 - Click on More sharing options… option
4 - Copy the link from the Direct Link field
5 - Use that URL to insert the image in your post, pasting the URL between [ img ] and [ /img ] tags
6 - Preview your message to ensure it renders as you wish.
- If you want to change the appearance of part of the text, you simply highlight it. Then you can use one of the buttons on the top row, to change its appearance. B = bold, I = italics, U = underline, S = strikethrough, Size = bigger* or smaller font, Font = Times font*, Color = different colour .
- You can nest these attributes: first you can make text bold, then select the text between the [start] and [/stop] brackets, to make it bold and underlined.
* [ size=5 ] = change by hand from [ size=3 ] to [ size=5 ]
* not all fonts work
If your text should really stand out, you may use the options Code or Quote . They give similar results, as shown below.
Code - highlight the text that you want to stand out, then click the Code button
Quote - highlight the text that you want to stand out, then click the Quote button
If you want to insert a list, click List and follow the instructions that appear.
  • bullets
or
  • numbers
and also
  • letters
Posted by macfrog at Nov 14, 2010, 9:28:53 PM
Re: How to share images and files
Thanks!
but how do i change a post i've made a while ago to add pictures, change type errors or similar things?
couldnt find an EDIT button ???
frank
Posted by Puybaret at Nov 15, 2010, 5:06:06 PM
Thank you Hans for this sum up.
I guess it's also available in mvnforum help, but sometimes it's not accessible. sad
Fortunately for us, this problem doesn't mean that mvnforum is unstable!
Posted by hansmex at Nov 15, 2010, 5:09:04 PM
Emmanuel,
Maybe it's an idea to make this a "sticky" post, that's always visible as the first one?
Posted by Puybaret at Nov 15, 2010, 5:24:01 PM
Done. Good idea! smile
Posted by kanalbert at Jun 8, 2013, 7:54:14 AM
Thank you so very much for this post sir. Its been most helpful to me. I just shared my first pics via mediafire
Posted by dorin at Aug 21, 2014, 5:20:52 PM
Un minor update for share image trow www.mediafire.com
1. Create an account on this site.
2. Upload there an picture.
3. Click on file. On right up corner click on Share.
4. On popup, on left bottom corner, click on More sharing options...
5. Chose the second option Direct Link to copy on clipboard.
6. Go to forum page, click on Image button and paste the link.
It must look like this http://www.mediafire.com/convkey/7863/21bfr0o4wa8wb0ifg.jpg
Posted by Jaffacat at Aug 16, 2015, 8:35:40 PM
If I am not using mediafire is there a way to get the link or so I have to store my pictures online?
/\__/\
(")(")_/
Posted by DlaminiSK at Dec 9, 2015, 5:59:18 AM
Morning
I would like to know, how do i share a post on this forum....just a simple message with now file attachment?
Posted by HawkDawg at Dec 9, 2015, 11:43:45 AM
Do you mean send a link to a post in the forum. If so, look for the [Link] link on the bottom right of each post. Click on that, then copy the link from the address bar. That will give you a link to that specific post.
Hawk
Posted by enkonyito at Jan 13, 2016, 3:03:26 AM
How to edit a post to add a downloadable attachment, like here ?
Posted by Puybaret at Jan 13, 2016, 10:49:51 AM
It's allowed only to a special group of forum users that I manage myself, and I just added you to this group. I prefer to manage the forum this way to avoid spams and anyway, as you'll see by yourself, the management of attachments isn't so great in this forum.
Posted by antonioperez2002 at Aug 18, 2017, 7:59:58 PM
Hello! I can't see in my post the photos that i've upload. Maybe its because its in PNG format? Please help me , thanks!
http://www.sweethome3d.com/support/forum/view...d,7929_lastpage,yes#35957
Posted by Puybaret at Aug 19, 2017, 9:33:45 AM
I fixed the links to your images, but I can't do that each time...
Next time, please be sure to use direct links to images as explained at the beginning of this thread, and preview your post to check how it works.
Posted by Alex210 at May 19, 2020, 7:36:23 AM
Noted. And thanks for sharing this...
