Print at Aug 21, 2019 12:15:35 AM
Posts: 15   Pages: 2   [ 1 2 | Next Page ]
Posted by choppyleo at Aug 11, 2014 1:01:13 PM
Problem of executing the source code on eclipse
I followed the instructions on Readme but when I executed the program I obtain the error messages as shown below. Can someone advice me on what to do at this stage
Exception in thread "main" java.io.FileNotFoundException : -Djava.ext.dirs=C:\Windows\System32\lib\windows\i386;lib (La syntaxe du nom de fichier, de répertoire ou de volume est incorrecte)
at java.io.FileInputStream.open (Native Method )
at java.io.FileInputStream.<init>(Unknown Source)
at org.freehep.util.io.ASCII85InputStream.main
(ASCII85InputStream.java:147 )
Posted by Puybaret at Aug 11, 2014 1:11:21 PM
Re: Problem of executing the source code on eclipse
You mixed up "Program arguments" and "VM arguments" in eclipse run configuration.
Posted by choppyleo at Aug 11, 2014 1:24:29 PM
Thanks, I have corrected that and now seeing this:
Usage: ASCII85InputStream filename
Posted by sree.arun.kr at Aug 11, 2014 1:41:54 PM
Can you explain how to build runnable jar (sweethome3d.jar=2.55MB)or an exicutable jar(sweethome3D.jar=22MB)or sunflow.jar-0.07.3i?.
[* Don't know about programming not only java but downloaded apache-tomcat7.0.zip +ant1.94.zip +JDK1.7 but next step ...? ]
Intreasted to learn and tweak. angel
Thanks in advance. applause
Posted by choppyleo at Aug 11, 2014 2:06:33 PM
I think I know how to creat that but I don't know how your reply is helpful to my question. Thanks
Posted by sree.arun.kr at Aug 11, 2014 2:17:39 PM
Importing source and editing java code is success then now looking for a 10-20 step tutorial from a developer/programmer.
All kinds of tips are welcome. applause
Posted by choppyleo at Aug 11, 2014 2:25:34 PM
Please sree.arun.kr I don't get clearly what you are driving at cos I asked a question and maybe I don't understand you but I still don't see how your reply helpful to my question on trying to execute sh3d on eclipse. Thanks
Posted by sree.arun.kr at Aug 11, 2014 2:35:52 PM
Question is simple
When I get the SH3D sourcecode then how to build a jar application using Eclipse.?
If you are successfull to create a sweethome3d.jar then share the methods you used.
Thats it. applause
Posted by choppyleo at Aug 11, 2014 2:57:50 PM
If you have already imported the source code on eclipse(but if not then follow the step of the Readme file).
After doing so then follow the steps on then site: http://www.wikihow.com/Create-an-Executable-File-from-Eclipse
Good Luck
Posted by sree.arun.kr at Aug 11, 2014 3:29:18 PM
Sourcecode importing and editing is done but exporting an exicutable jar is not enough successfull. Looks it need more tutorial about scripting. Anyway thanks for your help.(Your link is I already covered but thank you once again for sharing). Have a nice scriptingpeace
