Print at Feb 28, 2020, 1:53:15 AM
Posted by somuchfun at Feb 17, 2016, 7:16:04 PM
Cant start sh3d after plugin install (linux)
Linux OS:
Exception in thread "AWT-EventQueue-0" java.lang.UnsupportedClassVersionError: sh3d_plugin/AdvancedSettings_PhotoRendering : Unsupported major.minor version 52.0
I've tried re-exploding the sh3d.tar but I still get that error.
Where do plugins get installed so I can remove the offending one?
Thanks
Posted by AeowynFraser at Feb 17, 2016, 11:53:04 PM
Re: Cant start sh3d after plugin install (linux)
I too am having trouble opening my house after installing the update. I keep getting the following (this is just a small part of the error message I'm getting):
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000017dd1545
Exception Note: EXC_CORPSE_NOTIFY
For a copy of the complete error message:
http://www.mediafire.com/view/7e81lx219sgsx0x/Process.docx
I'm on an iMac.
If this is something that's needed to know, I've also updated my Java after I first realized I was having trouble opening my file.
Posted by Puybaret at Feb 18, 2016, 12:27:40 AM
Somuchfun, the error you report is about an incompatibility of the plugin with the Java version you use. To remove the plug-in, please read the end of the user's guide.
AeowynFraser, I don't think your problem is bound to plug-ins. Could you check if the problem happens with the previous version too?
Posted by AeowynFraser at Feb 18, 2016, 12:38:02 AM
Thank you for the reply, Puybaret.
I downloaded the older version and opened that version, but when I tried to open my file I got this error message:
It is the same type of message I'd gotten before unfortunately.
Posted by AeowynFraser at Feb 18, 2016, 12:45:00 AM
I just realized that I "highjacked" somuchfun's topic and I'm so sorry.
Posted by somuchfun at Feb 18, 2016, 1:30:41 AM
thanks! That did it...i was searching for the wrong file.
Posted by 60secs at Jun 10, 2016, 1:58:01 PM
Did you find the solution?
I have the same problem after installing some rendering plugins on Yosemite,
I'm getting this message
I reinstalled sh3d 5.2, updated java to v.8 update 91
I even installed the older version of sh3d 5.1 as Puybaret advised, nothing seems to work for me.
Please share your experience.
Posted by Puybaret at Jun 10, 2016, 3:29:16 PM
I guess you use an old version of this plug-in with the free Mac OS X installer version which uses Java 6 whatever more recent Java version you installed.
Remove the plug-in you installed (choose Go > Go to folder in the Finder and copy paste the folder name ~/Library/Application Support/eTeks/Sweet Home 3D/plugins) then try the latest version of that plug-in.
Posted by 60secs at Jun 13, 2016, 9:38:37 AM
There is no eTeks folder in application support.
it seems that I uninstalled that plug-in already, but sh3d still doesn't work.
when I try to install latest version which you provided, again same massage appears.
I downgraded to java 6 but doesn't matter. I think some file stuck somewhere which prevents sh3d from running,
Posted by 60secs at Jun 13, 2016, 10:28:19 AM
P.S. I don't need this plug-in at all, i just need my sh3d back :)
