Print at Jan 27, 2020 12:11:23 AM
Posts: 104   Pages: 11   [ Previous Page | 2 3 4 5 6 7 8 9 10 11 | Next Page ]
Posted by okh at Oct 13, 2018 8:21:52 PM
Thank you. Important part of the 6.0 launch. Quick test looks good. ok
Posted by Mike53 at Oct 14, 2018 11:44:51 AM
Hi enkonyito.
Have to say i found these light sources far more user friendly, thanks for the work you put into them and 1.6
Here i have used 4 opaque panels @ 25% and 4 "unviewable" panels, these are elevated to 1100mm, set to 10% and light the ceiling.
Thanks again
Posted by bdfd at Oct 18, 2018 7:28:24 AM
smile   Re: Photo-video rendering plug-in
PhotoVideoRendering-1.6 plug-in
- compatibility with Sweet Home 3D 6.0 and higher
- management of new light sources
- use of a light panel as room ceiling light
- added Speed and Frame Rate fields in the video panel
- possibility to choose the type of path in the video panel
OtherLightTypes-1.1 libraries compatible only with this plug-in
- PointLight_type: 1 light point with modifiable color
- SphereLight_type: 3 light spheres with modifiable color
- TrianglemeshLight_type: 3 light panels including 2 with modifiable color
Available in the Light sources category.
Can not change the color of lights.
None problem for me.
Automatic and color work fine ! applause
only 6.2 and nothing else - W10 64b
Asus TUF Z390 , Intel Core i9-9900K (3.6 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3000 Mhz, SSD M.2 512 Go + HDD 3 To,
MSI GeForce RTX 2080 8Go
Posted by UbuntuBirdy at Oct 22, 2018 1:00:05 AM
Is this just imagination or does the new plug-in render much faster?
Pascal
SH3D 6.2 / Ubuntu 18.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 1800x
Posted by YGYL at Oct 22, 2018 4:55:02 PM
biggrin   Re: Photo-video rendering plug-in
Today I rendered 16 times to test the difference between the different items in "Advanced settings>Quality 4>samplerAlgorithm" option.
I found that "bucket" rendering is the best quality and takes up the least amount of GPU. "Fast" rendering is the fastest quality consuming GPU.
If you want GPU to take up a little more, I think there is only one way. Render with a fast rendered quadruple resolution. Then use software to reduce the screen size by 4 times.
Original image, not rendered
"bucket"-1000X500 Rendering time, 40 minutes
"fast"-4000X2000 Reduce size 1000X500 Rendering time, 26 minutes
The difference is only in the processing of light and shadow. Square rendering is more natural. But the rendering time for fast rendering is 40% less.
So I recommend
1.adding one in the option, 4x supersampling for fast rendering.
2.And render with smaller squares.
3.Support for rendering pauses.
4.And automatically save the file.
5.Allow rendering of 16000X8000 resolution
Posted by YGYL at Oct 25, 2018 12:13:58 PM
Another important thing to forget is to add a "pause" button after the rendering starts.
The rendering time is very long and uses 100% CPU. If you encounter individual things at this time, you can't do it.
Posted by enkonyito at Feb 9, 2019 12:43:32 AM
At this point, the plug-in will not evolve any more.
Compatibility with future versions of Sweet Home 3D will be maintained, as far as possible, for changes in rendering. (PhotoRenderer.java history )
Enko Nyito
Posted by enkonyito at Apr 24, 2019 10:23:13 PM
While waiting for the next version of Sweet Home 3D, here is the latest beta 1.7 of the plug-in. This allows you to test the ambient lighting panels by activating "Add all ceiling lights" in the standard version of SH3D.
To view the location of panels in the plan using polylines, you can use this utility.
Posted by Mike53 at May 5, 2019 6:25:04 PM
Not sure, well no idea at all really, how much a plug can link with the main software, but, would it be possible to move the choice of having the ambient lighting on, and its slider, away from the render modification window and onto the room modification window.
This way each room could be controlled individually, on, off and brightness.
Posted by enkonyito at May 6, 2019 4:45:31 PM
It would be possible as here but it imposes some constraints.
Given the size of rooms modification panel, the slider would not be very readable.
The addition of such a feature is possible in a derived version but will require an update to each new version of Sweet Home 3D.
The plug-in will have to be compatible with these 2 versions (standard and derived).
The easiest way is to make an official request for the ceiling lights power feature to be integrated into the standard version of SH3D.
The plug-in will be able to retrieve this information and manage the ambient lighting panels.
Enko
