Print at Aug 26, 2019 3:25:10 AM View all posts in this thread on one page
Posted by rhawke at Jan 27, 2017 7:19:05 AM
Recalculate Room Points
After I move a wall by a few inches or move a door left or right along a wall, I have to update the room. Right now the easiest way is to delete the room and add it again with double click (because fixing the room to match a moved door manually takes a long time).
But then I have to select the textures again, change labels, etc.
It would be nice to have a button inside the "Modify Room" dialog box that lets you recalculate the room points (basically same calculation as when I double click in the center of the room). You could simulate this by assuming I double clicked into the center of the selected room.
Or is there already a good approach to this problem that I am missing?
Posted by Puybaret at Jan 27, 2017 4:52:02 PM
Re: Recalculate Room Points
I had the idea to add an option to recalculate rooms like you proposed.
But I already introduced a solution to simplify this operation: cut the room, create the room with double click and select Edit > Paste style menu item.
Posted by rhawke at Jan 27, 2017 5:04:45 PM
Thanks Emmanuel, this is a good tip. I will use this from now on!
For new users the idea to have a button to recalculate would be nice though, so if it is easy to implement I think it would a way to make the software even more intuitive and user friendly (It already is AWESOME!)
Posted by Miker777 at Jan 27, 2017 7:10:52 PM
Hi rhawke
Sounds like a good idea to me, i never get door positions right 1st time, or 2nd come to that.
