Print at Jun 27, 2019 11:10:11 AM
Posted by czgeorge58 at Mar 29, 2017 10:28:51 AM
Rotating textures
Hi, srz for mz english, but is there any way how to rotate textures - not as object, but only textures?I see 0, 45 and 90, but sometimes i must to change it 34 or 62.. it depends od walls and floor..
Posted by Puybaret at Mar 31, 2017 12:38:44 AM
Re: Rotating textures
The program is prepared to handle any angle for textures rotation, but the user interface is not here yet. Please, wait a future version or if you're able to edit an XML file, update the angle attribute (in radians) of the texture you want to change in the Home.xml entry of your sh3d file.
Posted by Miker777 at Mar 31, 2017 5:52:03 PM
If it is floors you wish to texture you can create your room, add texture, then rotate your room by increments of 1 degree as apposed to the texure, as i did here with the dark carpet, once you are happy with texture position export then import the room.
