Print at Sep 27, 2020, 8:37:33 AM
Posted by Puybaret at Jan 16, 2019, 7:39:45 PM
Sweet Home 3D 6.1
Hello,
Here's a Beta version of the version 6.1. [Links removed]
This will be mainly a maintenance release with bug fixes and a few improvements:
- Interpreting math expressions when length unit is not cm now works correctly
- It fixes offscreen rendering when depth size is not supported
- It brings a few improvements in the plan: a more efficient management of the cache of top view icons for similar furniture, a correct drawing of top views and multi line texts at large zoom factor, a better management of icons updates within updated groups
- It allows to toggle the selection of an object in the furniture list without unselecting other items in home
- It brings support for mirrors on hinge and rail with sweethome3d_window_mirror_on_hinge_ / sweethome3d_window_mirror_on_rail_ prefixes
- Information about the used memory was added in the About dialog box:
- It also fixes some issues related to right to left orientation used in languages like Arabic or Hebrew. This will allow to welcome soon a new Arabic translation SH3L file prepared by MFM Dawdeh, as shown below.
I will be happy to read your feedback about your tests. Hope you won't find any regression...
[Note from developer: Sweet Home 3D 6.1 was released on January 22, 2019]
Posted by ndorigatti at Jan 17, 2019, 11:44:56 AM
Re: Sweet Home 3D 6.1
Thank you!!!!!!!!!!
I have a model almost ready for this! I just need to find a couple of hours to update the model and test, it's been a tough start of the year for my free time :D
From the changelog, a lot of sweet updates!
Posted by Puybaret at Jan 22, 2019, 7:53:50 PM
Sweet Home 3D 6.1 was released today.
Thanks for your tests smile
Posted by ndorigatti at Jan 23, 2019, 10:41:48 AM
Dear Puybaret,
I can confirm that mirrors on doors with hinge are working and rocks!
I did not remember that when asking for the feature I already did rename the item in the correct way, so that I lost time to open and find the files, just for seeing that were already ok, so Opened up SH 6.1 and tested, very good! Now we can do almost anything with doors!
I have to admit that since I started using it (v5.4) it exponentially added features and became better, just to be almost perfect for what I need now!
Thank you, and congratulations for this wonderful software (from a developer and from a user)!
Posted by UbuntuBirdy at Jan 23, 2019, 11:23:28 AM
...it exponentially added features and became better, just to be almost perfect for what I need now!
AMEN
Pascal
SH3D 6.3 / Ubuntu 20.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 1800x
Posted by Puybaret at Jan 23, 2019, 3:08:31 PM
Thanks for your feedback smile
For your information, I released again the binaries of Sweet Home 3D 6.1 a few minutes ago, because I discovered that it wasn't possible to ignore prices in preferences pane once you chose a currency. Version in About dialog box is now 6.1a. Sorry for any inconvenience.
Posted by Puybaret at Feb 1, 2019, 4:29:49 PM
I just released a new version 6.1.2 of Sweet Home 3D, a small update which fixes shortcuts management under macOS and a regression which prevented from changing the dash style of polylines.
Using shortcuts with a non Latin keyboard under macOS was provoking double actions (double undos, double save dialog boxes, etc!), and I felt that this bug was serious enough to avoid waiting longer to be fixed.
Posted by Raevlav at Feb 14, 2019, 7:35:30 PM
Win7 64bit OS. When opening a file in 64-bit SH version it crushes right on the start at most of the times with a 3d Error: "Sweet Home 3D will exit now because of a fatal error in the 3D rendering system of your computer. Pleas update the DirectX/OpenGL drivers of your computer graphics card"
32-bit version of SH works fine.
Posted by masterrazor at Feb 18, 2019, 5:54:26 AM
I've been having the same issue since every version after 5.4.
Posted by Puybaret at Feb 18, 2019, 7:26:32 AM
Raevlav, Masterrazor, sorry but you should live with this 32 bit "official" solution. I know it might cause some memory limitations, but I have no idea how to use a recent Java 64 bit version in your cases.
The only solution that might still work for a while is to install a 64 bit version of Sweet Home 3D that works for you, backup the jre8 folder found in the installation folder, install the 64 bit version of Sweet Home 3D 6.1.2 and replace its jre8 folder by the backup you kept.
Posted by bdfd at Feb 27, 2019, 7:40:15 PM
Since lastest version (6.1.2) sh3d is blocked when I execute 'create a photo' and just after I move anything in 2D frame…
sad
SH3D 6.4.2 and nothing else - W10 64b
Asus TUF Z390 , Intel Core i9-9900K (3.6 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3000 Mhz, SSD M.2 512 Go + HDD 3 To,
MSI GeForce RTX 2080 8Go
Posted by Puybaret at Feb 28, 2019, 10:17:38 AM
Bdfd, please give more details about your issue, possibly with a simple example. I tried to reproduce it but didn't notice such problems even on large homes.
Posted by bdfd at Mar 2, 2019, 6:57:15 AM
Sometimes, not always, dépends perhaps of the size of the project (?)
Anything like : updating point of view, Moving furniture…
sad
Posted by bdfd at Mar 31, 2019, 9:22:31 AM
shock   Re: Sweet Home 3D 6.1
Some details : sh3d 6.1.2 doesn't move when I try to move a furniture when a rendering is calculating... before appears the first little square.
sad biggrin sick
