Print at May 27, 2020, 11:04:03 AM
Posted by enkonyito at Feb 28, 2019, 5:43:08 PM
colorful flowers
Small design highlighting flowers in transparent vases on illuminated supports.
Enko
Posted by UbuntuBirdy at Feb 28, 2019, 5:56:41 PM
Re: colorful flowers
Incredibly cool! I would have installed a weak light in the pool.
Pascal
SH3D 6.3 / Ubuntu 18.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 1800x
Posted by VeroniQ at Feb 28, 2019, 6:33:35 PM
It looks nice!
Posted by enkonyito at Mar 1, 2019, 4:06:53 PM
Thank you both!
I did not think about it. wink
Posted by AdeleAlli at Mar 1, 2019, 8:43:27 PM
The result you obtained is really impressive enko, brilliant! :)
Adele
Posted by enkonyito at Mar 2, 2019, 12:40:34 AM
Thanks Adele!
For the illuminated supports I used a transparent cube with an opaque light panel in the bottom and an unviewable light panel on the top.
The ambient lighting is made by a sky texture.
Posted by Mike53 at Mar 2, 2019, 5:45:59 PM
Hi enkonyito, nice job on these images, but, "The ambient lighting is made by a sky texture". Does this mean you changed the sky color/texture to ??? and then checked the box for enhanced lighting, or that they were made with path settings?
MIke
Posted by enkonyito at Mar 3, 2019, 1:34:01 AM
Hi Mike, no GI path here but just a IBL rendering (sky texture + Enhance external brightness checked) without visible sunlight.
Posted by enkonyito at Mar 3, 2019, 1:38:10 AM
And with these half-immersed light globes?
Unfortunately, the horizon line is visible. sad
Posted by bdfd at Mar 3, 2019, 7:02:16 AM
@enko,
One thing to do : choose a black texture for sky and ground.
I did same thing for martian adventures… wink
Back to 6.1.2 (6.2 & 6.3 too heavy) and nothing else - W10 64b
Asus TUF Z390 , Intel Core i9-9900K (3.6 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3000 Mhz, SSD M.2 512 Go + HDD 3 To,
MSI GeForce RTX 2080 8Go
Posted by UbuntuBirdy at Mar 3, 2019, 7:34:33 AM
What about a big hollow black sphere around your scene?
Pascal
Posted by enkonyito at Mar 4, 2019, 4:04:54 PM
@bdfd
I sometimes use this trick but for this project we would not see the contour of the transparent supports.
black background
dark background
@UbuntuBirdy
This would be a solution for a project without IBL rendering.
Posted by UbuntuBirdy at Mar 4, 2019, 8:00:22 PM
@UbuntuBirdy
Oh man, I just picture myself cursing because the renderings are always too dark... confused
Pascal
Posted by enkonyito at Mar 4, 2019, 9:23:11 PM
I turned off some lights to show the influence of IBL rendering on the horizon line with a uniform background (part of the sky and ground of the same color).
I do not think that with a half-sphere and light panels I would get this desired atmosphere in the first 4 images. Unless the inside of the half-sphere emits light as for the sky.
Posted by AnnWanges at Mar 7, 2019, 1:33:13 PM
Wow. These are incredible ones. The coloring is my jam)
Posted by Xiste at Mar 7, 2019, 10:39:48 PM
Enko, you are a wizard!
I have a lot to learn.
