Print at Apr 9, 2020, 4:14:56 AM View all posts in this thread on one page
Posted by enkonyito at Apr 4, 2019, 5:08:05 AM
Saved property not taken into account correctly
In a derived version of SH3D-6.1, I added a new CEILING_LIGHT_ENABLED room property.
Although it is saved in the Home.xml file after modifying the HomeXMLExporter.java file, only the default value is taken into account when opening a project.
I based on the methods related to the CEILING_VISIBLE room property but it seems that I missed something because the expected operation is not the same.
Posted by Puybaret at Apr 4, 2019, 2:58:59 PM
Re: Saved property not taken into account correctly
The additional attributes you save in a subclass of HomeXMLExporter should be read in a subclass of HomeXMLHandler.
But why don't you manage your additional information with the methods setProperty / getProperty available on subclasses of HomeObject, like the Room class? This would prevent you from subclassing classes which handle XML files.
Posted by enkonyito at Apr 5, 2019, 11:49:38 PM
Indeed, it's more practical!
<room level='level0' areaVisible='true' areaXOffset='-130.0' areaYOffset='55.99997' floorColor='FF586178' ceilingVisible='false'>
<point x='503.75' y='50.30641'/>
<point x='503.75' y='426.80637'/>
<point x='11.25' y='426.8065'/>
<point x='11.25' y='50.30641'/>
</room>
<room level='level1' areaVisible='true' areaXOffset='-132.15613' areaYOffset='109.9032' floorVisible='false' floorColor='FF586178'>
<property name='ceilingLightEnabled' value='true'/>
<point x='503.8' y='50.3'/>
<point x='503.8' y='426.8'/>
<point x='11.2' y='426.8'/>
<point x='11.2' y='50.3'/>
</room>
By selecting rooms of different state:
- with NullableCheckBox, I get the error
Caused by: java.lang.NullPointerException
at com.eteks.sweethome3d.viewcontroller.RoomController.setCeilingLightEnabled(RoomController.java:982)
at com.eteks.sweethome3d.viewcontroller.RoomController.updateProperties(RoomController.java:420)
at com.eteks.sweethome3d.viewcontroller.RoomController.<init>(RoomController.java:119)
at com.eteks.sweethome3d.viewcontroller.PlanController.modifySelectedRooms(PlanController.java:1691)
- with JCheckBox or by capturing the exception, the global state is not indicated (empty).
Posted by Puybaret at Apr 6, 2019, 11:54:42 AM
A NullableCheckBox instance isn't nullable by default. You should call setNullable(true) to be able to call setValue(null).
Just look in source code, there are plenty of examples.
Posted by enkonyito at Apr 6, 2019, 10:45:12 PM
My mistake, by declaring the ceilingLightEnabled global variable in the RoomController.java file I had used boolean instead of Boolean . sad
Thanks!
