Print at Feb 21, 2020, 4:44:28 AM View all posts in this thread on one page
Posted by rubenarnowaltner at Apr 9, 2019, 10:57:14 PM
cool   Function: "Plane / Import Background Image" in Sweet Home 3D version 6.1.2
Hello
I am glad to see the function where I can with a background of a 2D plane copy a plane or work on it, however I follow the menu option: "Plane / Import Background Image", I indicate the image, show it to me, ask me to indicate the cms width of the image, and the initial position of the image and then I accept, but I do not see in the drawing panel the background with my image that is a 2D plane to copy, what should I do to see it and copy ?
Greetings and already thank you very much.
Ruben Arno
ESPAƑOL
Funcion: "Plano / Importar Imagen de Fondo" en Sweet Home 3D version 6.1.2
Hola
Me alegro ver la funcion donde puedo con un fondo de un plano en 2D copiar un plano o trabajar sobre el, sin embargo sigo la opcion del menu: "Plano / Importar Imagen de Fondo", le indico la imagen, me la muestra, me pide le indique los cms de ancho de la imagen, y la posicion inicial de la imagen y luego pongo aceptar, pero no veo en el panel de dibujo el fondo con mi imagen que es un plano 2D para copiar, que debo hacer para verlo y copiar ?
Saludos y desde ya muchas gracias.
Ruben Arno cool
Posted by Puybaret at Apr 10, 2019, 3:01:07 PM
Re: Function: "Plane / Import Background Image" in Sweet Home 3D version 6.1.2
Please read the FAQ Importing a background image seemed to run correctly but no image appears in plan. What is going on?
