Print at Feb 21, 2020, 4:48:50 AM
Posts: 22   Pages: 3   [ 1 2 3 | Next Page ]
Posted by dorin at Apr 15, 2019, 6:50:01 PM
Rooms Surfaces plug-in
In category YAUP (Yet Another Useless Plugin),
I present You my second attempt in java (and in programming in general).
It was necessary in my learning curve to my initial purpose: to make a useful plugin.
I hope it will be ready before the end of the world.
Until than, this plugin could be find also on Source Forge here .
Few image:
The plug-in could be find here:Rooms Surfaces plugin .
Hope somebody can use it.
Posted by dorin at Apr 19, 2019, 8:36:31 AM
Re: Rooms Surfaces plug-in
New version (1.1) with few improvements.
Now, by check/uncheck the SUBTOTAL, check/uncheck all rooms at that level.
Checking a room on unchecked level will also check the level.
The plug-in are under menu Tools->Total room's surface.
I recommend to remove (uninstall) other plug-ins with the same functionality.
The new version could be downloaded from here:Roos Surfaces v1.1
or from Source Forge here.
Posted by UbuntuBirdy at Apr 19, 2019, 10:33:26 AM
Very nice plugin! Saves me the creation of Excel-Sheets like i've done so far! Thanks man!!!
Would be great if we can sort the rooms for example living area and technical area.
Pascal
SH3D 6.2 / Ubuntu 18.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 1800x
Posted by bdfd at Apr 19, 2019, 10:50:10 AM
angry   Re: Rooms Surfaces plug-in
New version (1.1)...The new version could be downloaded from here:Roos Surfaces v1.1
Downloaded and installed but nothing opens (after choosen the option in tools menu) ??? biggrin
Why ?
sick
only 6.2 and nothing else - W10 64b
Asus TUF Z390 , Intel Core i9-9900K (3.6 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3000 Mhz, SSD M.2 512 Go + HDD 3 To,
MSI GeForce RTX 2080 8Go
Posted by dorin at Apr 19, 2019, 1:24:22 PM
Few possibilities:
-if the home are empty the plug-in are gray;
-also if the home don't have any rooms;
Please keep me up to date!
Posted by dorin at Apr 19, 2019, 4:39:03 PM
Wile there are two people interested in use (test) this plug-in, I feel responsible to give few more explanations.
NOTE "room" = object created with room creation tool; in SH3D 3 or more connected walls don't represent a room.
When lance SH3D the plug-in verify if there are any rooms; if not is inactive.
After open an home plan it make the same verification; if find at least one room, the plug-in became active and could show the total surface even there are only one room.
If the home plane have multiple levels but not all own room(s) the plug-in will show and compute ONLY those WITH rooms.
At lance will make the total of rooms find on home plan. Then the user can check/uncheck the included surfaces in total.
@UbuntuBirdy maybe You're right but I don't find another criteria to make this.
Personally I've organized the home plan on multi-levels, some of them at same elevation or very close (<10 cm) for different purposes (electric, water and hot,furniture etc.).
Some of them have rooms some not.
The plug-in show me only those with rooms sorted by levels.
Unfortunately most rooms have "No name".
If You or someone else find a bather way I'll be happy.
Until there the rest of the necessary tasks could be made in LO Calc or MS Office.
I deactivate the option to open the csv file after creation because I don't know what could happen under different OS. Personally I don't like to open instantly.
Remember I'm not a programmer. I get start learning few month ago.
So, good luck cool
Posted by bdfd at Apr 19, 2019, 5:58:38 PM
love struck   Re: Rooms Surfaces plug-in
Few possibilities:
None of the two possibilities.
So, I see the plugin in options and in the directory of the librairies.
I tried to use the plugin on an existing project but nothing arrives...
On which OS did you create it ?
confused
Posted by Puybaret at Apr 19, 2019, 7:23:41 PM
Bdfd, it's probably not a problem of OS.
Please run the program from the command line with the following command line to get possible errors:
C:\Program Files\Sweet Home 3D\SweetHome3D.exe 2>log.txt
This should create a log.txt file in your home folder which might contain some useful information for Dorin.
Posted by dorin at Apr 19, 2019, 9:57:33 PM
@bdfd,
For your sake I've repair an Win10 (don't want to work after crash of an 3Tb HDD and I don't boot on it for couple of months);
-I've download and install the installer version of SH3D for win;
-I've chose 32 bit when prompted;
-make a test to see if run; Run!;
-download the plugin from this site;
-double click on it and was automatically installed;
-run SH3D; verify in about; plugin are there.
-open same of the demo files provided by SH3D;
-menu Tools->Total room's surface;
==>the table show up with all expected data on it;
-I've made a test for Export to CSV and work also;
CONCLUSION: on my side are work correctly even under Windows.
Suggestion 1:
- rename the Sweet Home 3D folder to Sweet Home 3D-1 in
[USER]\ApplicationData\ to preserve actual configuration;
- restart SH3D and the program will recreate the necessary files and directory;
- reinstall the plug-in and test it with demo files;
Suggestion 2:
Verify the java version; I've made it for jre8 or high.
Please let me (us) know if You manage it to work.
You're experience could be useful for other users.
@Emmanuel,
I'm flattered if You think I could understood something from a log file produced by Windows. Scarcely I decipher the Eclipse debug.
I've spend 2 weeks to fix an NullPointerException and another 2 weeks for an StackOverFlow learning and try 10~14 hour/day.
Well, I don't give up; I continue learning wile I've made only two steps.
Posted by UbuntuBirdy at Apr 19, 2019, 10:21:15 PM
@dorin - two or three checkboxes for each room which can be sorted for example.
But you're right, this would be a nice to have feature, not an must have one.
Pascal
