FRANCE
windows 3D builder
Impossible to import a 3d furniture created with 3D BUILDER (windows 10) en .OBJ, it worked well before, but now the import only works with a 3d .DAE model that removes colors and textures ....
Re: windows 3D builder
Difficult to help you without an error OBJ file. Could you share one or send it one to me?
FRANCE
it seems that the problem arises as soon as you add colors to the model in 3D builder. A simple shape without color does not pose a problem and is imported without error into 3D sweethome.
Thanks for your file. The OBJ file can't be read because it doesn't respect the OBJ format specifications. As it's a text format, you can check by yourself: lines starting by "v" are supposed to describe a vertex with the 3 values of its coordinates (and a possible 4th value used as a weight). In the file you sent, "v" lines are followed by 6 values, making it wrong. It will work if you remove the trailing 3 numbers of "v" lines.
FRANCE
in this line for example : "v -60.698318 69.639313 141.979401 0 0 0" how many values and wich numbers can i remove ? how did you found the wrong lines in my 3d model ?
I think you should rather use another tool or a different export format...
