Re: Project suddenly went corrupt.
I don't think it's lost. If you want to try by yourself, edit the Home.xml file in your .sh3d file and remove the XML elements which contains some attributes equal to NaN (probably the <compass ... /> line from your image). Of course, make a backup of your .sh3d file first. If making this change is too much for you, please send me your .sh3d file or the Home.xml file it contains.
Normally it's not too much for me to edit xml-files. But these are files ( like marker files) that I export to xml prior to editing them. I could find any option to export xml form SH3D. I have searched the forum for Home.xml, and found a lot of info about xml and Home.xml. Like this: To take an example: extract the Home.xml from your SH3D file...
The only thing I could not find was HOW to extract the xml-file from the sh3d-file. This is probably so simple that it needs no explanation, but I have to admit that my meagre intellect could use a step-by-step tutorial.
Once I have the extracted xml-file, however, I think I'll be okay. :)
A .sh3d file is actually a ZIP file that you can open with any zip tool. Open it and you’ll find that Home.xml in it.
