Total posts in this thread: 5
Previous Thread This topic has been viewed 1047 times and has 4 replies Next Thread
justthewayur
.png image on wall or object with transparancy...
Can I make either a vertical wall or object, apply a .png image of a tree that has transparancy around the tree, then see that in a 3d view and have the transparent areas of the .png image be invisible, the same as a .png behaves as a 2d image ?
Thank you.
Justina
[Apr 1, 2020, 4:01:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: .png image on wall or object with transparancy...
You may do that on the side of a thin box found in Miscellaneous category, but not on walls.
[Apr 2, 2020, 6:43:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
justthewayur
Thank you.
May I ask for a tip please on how to plan the correct size of the image and dpi if I wish a real life size of 5 feet tall by 4 feet wide, and maintain the aspect ratio of the image on the box without stretching.
Cheers.
[Apr 3, 2020, 5:13:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's explained in this tip.
[Apr 3, 2020, 5:36:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
justthewayur
Thank you.
[Solved]
[Apr 8, 2020, 4:34:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
