Remove default libraries from Sweethome
This topic has been viewed 6927 times and has 4 replies
Thread status: Active
Questions about Sweet Home 3D installation [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Post Reply New Topic
guymclaren
Country: South Africa
Post by guymclaren »
I am finding the default libraries take too much space in the user interface, How do I delete them, mostly they are not applicable. The doors and windows are a different design to what we use in South Africa, The kitchen stuff also all wrong. I am creating my own models and want to make a default library with those.
Help please.
User avatar
Country: Paris, France
Contact:
Re: Remove default libraries from Sweethome
Post by Puybaret »
Default library is stored in the [font=courier new]furniture.jar[/font] file found in the lib subfolder of Sweet Home 3D installation folder. You can delete that file if you want, or move it elsewhere.
guymclaren
Thanks very much
guymclaren
Thank you I found the .jar files, If I were to want to create a replacement .jar file for the furniture and include it in the package as a standard, how would I go about doing that, For the sake of argument, If I wanted to create a fork of sweethome 3d aimed at South Africa with South African models and objects.
I would want to offer a limited range of SA doors windows, kitchen units, sanitary ware and furniture from known manufacturers, in order to sell a full set of each of these models as add ons to the Construction Industry.
The standard furniture as in the standard package has very little that would match South African needs.
User avatar
T3NZ3N
Country: 天下
Post by T3NZ3N »
You could either delete all the ones in the library you don't want, then add the ones you do want, then export with the plug in all the furniture you have to *sh3f file, and use that.
Or, you could rename the *sf3f file in the /data/furniture/ folder to a *.zip extension, the extract that, and select all the ones you wanted, combine them with the ones you have, then import them one by one
Or you could use the FLE and copy all of the individual Folder Files you unzipped into the same folder, together with all of your own furniture files for your market, and import all of the obj files into FLE and export your new *.sh3f library
Who is online
Users browsing this forum: Google [Bot], MSN [Bot]
