SebStaeubert
Germany
Startup problem with initializing 3D (Debian 10 Linux, Intel i5-4570 onboard graphic)
Exception starting via script:
./SweetHome3D Exception in thread "main" java.lang.ExceptionInInitializerError at javax.media.j3d.GraphicsConfigTemplate3D.isGraphicsConfigSupported(GraphicsConfigTemplate3D.java:348 ) at com.eteks.sweethome3d.j3d.Component3DManager.createGraphicsConfigurationTemplate3D(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source) Caused by: com.jogamp.opengl.GLException: Profiles [GL4bc, GL3bc, GL2, GLES1] not available on device null at com.jogamp.opengl.GLProfile.get(GLProfile.java:1039) at com.jogamp.opengl.GLProfile.get(GLProfile.java:1050) at com.jogamp.opengl.GLProfile.getMaxFixedFunc(GLProfile.java:803) at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:131) at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267) ... 7 more
Java version:
java -version openjdk version "1.8.0_232" OpenJDK Runtime Environment (build 1.8.0_232-8u232-b09-1~deb9u1-b09) OpenJDK 64-Bit Server VM (build 25.232-b09, mixed mode)
GLX-Info
glxinfo
name of display: :1 display: :1 screen: 0 direct rendering: Yes server glx vendor string: SGI server glx version string: 1.4 server glx extensions: GLX_ARB_create_context, GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample, GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_no_config_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_make_current_read, GLX_SGI_swap_control client glx vendor string: Mesa Project and SGI client glx version string: 1.4 client glx extensions: GLX_ARB_context_flush_control, GLX_ARB_create_context, GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync GLX version: 1.4 GLX extensions: GLX_ARB_create_context, GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync Extended renderer info (GLX_MESA_query_renderer): Vendor: Intel Open Source Technology Center (0x8086) Device: Mesa DRI Intel(R) Haswell Desktop (0x412) Version: 18.3.6 Accelerated: yes Video memory: 1536MB Unified memory: yes Preferred profile: core (0x1) Max core profile version: 4.5 Max compat profile version: 3.0 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.1 OpenGL vendor string: Intel Open Source Technology Center OpenGL renderer string: Mesa DRI Intel(R) Haswell Desktop OpenGL core profile version string: 4.5 (Core Profile) Mesa 18.3.6 OpenGL core profile shading language version string: 4.50 OpenGL core profile context flags: (none) OpenGL core profile profile mask: core profile OpenGL core profile extensions: GL_3DFX_texture_compression_FXT1, GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend, GL_AMD_multi_draw_indirect, GL_AMD_query_buffer_object, GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_trinary_minmax, GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index, GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5, GL_APPLE_object_purgeable, GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility, GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_blend_func_extended, GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control, GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader, GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_derivative_control, GL_ARB_direct_state_access, GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts, GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location, GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport, GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB, GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_indirect_parameters, GL_ARB_instanced_arrays, GL_ARB_internalformat_query, GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect, GL_ARB_occlusion_query2, GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp, GL_ARB_program_interface_query, GL_ARB_provoking_vertex, GL_ARB_query_buffer_object, GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops, GL_ARB_shader_atomic_counters, GL_ARB_shader_bit_encoding, GL_ARB_shader_clock, GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote, GL_ARB_shader_image_load_store, GL_ARB_shader_image_size, GL_ARB_shader_objects, GL_ARB_shader_precision, GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine, GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod, GL_ARB_shader_viewport_layer_array, GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing, GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader, GL_ARB_texture_barrier, GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32, GL_ARB_texture_buffer_range, GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map_array, GL_ARB_texture_filter_anisotropic, GL_ARB_texture_float, GL_ARB_texture_gather, GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels, GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8, GL_ARB_texture_storage, GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2, GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced, GL_ARB_transform_feedback_overflow_query, GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object, GL_ARB_vertex_shader, GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_viewport_array, GL_ATI_blend_equation_separate, GL_ATI_texture_float, GL_EXT_abgr, GL_EXT_blend_equation_separate, GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB, GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp, GL_EXT_provoking_vertex, GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_shader_integer_mix, GL_EXT_shader_samples_identical, GL_EXT_texture_array, GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc, GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra, GL_EXT_vertex_attrib_64bit, GL_IBM_multimode_draw_arrays, GL_INTEL_performance_query, GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error, GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness, GL_MESA_pack_invert, GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba, GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_packed_depth_stencil, GL_NV_texture_barrier, GL_OES_EGL_image, GL_S3_s3tc
OpenGL version string: 3.0 Mesa 18.3.6 OpenGL shading language version string: 1.30 OpenGL context flags: (none) OpenGL extensions: GL_3DFX_texture_compression_FXT1, GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend, GL_AMD_multi_draw_indirect, GL_AMD_query_buffer_object, GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_trinary_minmax, GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5, GL_APPLE_object_purgeable, GL_APPLE_packed_pixels, GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility, GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_blend_func_extended, GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control, GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader, GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control, GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location, GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport, GL_ARB_fragment_program, GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB, GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_indirect_parameters, GL_ARB_instanced_arrays, GL_ARB_internalformat_query, GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect, GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2, GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp, GL_ARB_program_interface_query, GL_ARB_provoking_vertex, GL_ARB_query_buffer_object, GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops, GL_ARB_shader_atomic_counters, GL_ARB_shader_bit_encoding, GL_ARB_shader_clock, GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote, GL_ARB_shader_image_load_store, GL_ARB_shader_image_size, GL_ARB_shader_objects, GL_ARB_shader_precision, GL_ARB_shader_storage_buffer_object, GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod, GL_ARB_shading_language_100, GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_texture_barrier, GL_ARB_texture_border_clamp, GL_ARB_texture_compression, GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3, GL_ARB_texture_filter_anisotropic, GL_ARB_texture_float, GL_ARB_texture_gather, GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat, GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels, GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8, GL_ARB_texture_storage, GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2, GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced, GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix, GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers, GL_ATI_separate_stencil, GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array, GL_EXT_copy_texture, GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB, GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object, GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp, GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_shader_integer_mix, GL_EXT_shader_samples_identical, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_array, GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer, GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra, GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate, GL_INTEL_performance_query, GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error, GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness, GL_MESA_pack_invert, GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba, GL_MESA_window_pos, GL_NV_blend_square, GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil, GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier, GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image, GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 18.3.6 OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10 OpenGL ES profile extensions: GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5, GL_APPLE_texture_max_level, GL_EXT_base_instance, GL_EXT_blend_func_extended, GL_EXT_blend_minmax, GL_EXT_buffer_storage, GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float, GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_EXT_discard_framebuffer, GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers, GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex, GL_EXT_frag_depth, GL_EXT_geometry_point_size, GL_EXT_geometry_shader, GL_EXT_gpu_shader5, GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays, GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp, GL_EXT_primitive_bounding_box, GL_EXT_read_format_bgra, GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_separate_shader_objects, GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_shader_integer_mix, GL_EXT_shader_io_blocks, GL_EXT_shader_samples_identical, GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader, GL_EXT_texture_border_clamp, GL_EXT_texture_buffer, GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_anisotropic, GL_EXT_texture_format_BGRA8888, GL_EXT_texture_norm16, GL_EXT_texture_rg, GL_EXT_texture_sRGB_decode, GL_EXT_texture_type_2_10_10_10_REV, GL_EXT_unpack_subimage, GL_INTEL_performance_query, GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error, GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness, GL_MESA_framebuffer_flip_y, GL_MESA_shader_integer_functions, GL_NV_draw_buffers, GL_NV_fbo_color_attachments, GL_NV_image_formats, GL_NV_read_buffer, GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image, GL_OES_EGL_image_external, GL_OES_EGL_image_external_essl3, GL_OES_EGL_sync, GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_depth_texture, GL_OES_depth_texture_cube_map, GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex, GL_OES_element_index_uint, GL_OES_fbo_render_mipmap, GL_OES_geometry_point_size, GL_OES_geometry_shader, GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer, GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box, GL_OES_required_internalformat, GL_OES_rgb8_rgba8, GL_OES_sample_shading, GL_OES_sample_variables, GL_OES_shader_image_atomic, GL_OES_shader_io_blocks, GL_OES_shader_multisample_interpolation, GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_surfaceless_context, GL_OES_tessellation_point_size, GL_OES_tessellation_shader, GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_buffer, GL_OES_texture_cube_map_array, GL_OES_texture_float, GL_OES_texture_float_linear, GL_OES_texture_half_float, GL_OES_texture_half_float_linear, GL_OES_texture_npot, GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array, GL_OES_vertex_array_object, GL_OES_vertex_half_float, GL_OES_viewport_array
70 GLX Visuals ...
The problem occurs since i have to change my graphics card from Radeon HD 3850 to intel onboard graphics. So in principle i have a working setup except the 3D graphic setup issue with SH3D. Other 3D Appl. work, e.g. glxgears.
THX, Sebastian
