2D version limitations: Request for solutions
Greetings.
On the 2D version of the program I cannot uncheck "keep proportions" in the furniture properties. Is there any solution? Moreover, I would like to change the rendering settings—please note that I carry out renderings in headless mode.
Re: 2D version limitations: Request for solutions
The Keep proportions check box can't be unchecked when it's too complicate too deform furniture, for example when you modify an opened door or a group which contains some objects rotated around an horizontal axis. For opened doors, close it first and for groups modify the objects within the group.
To change settings in headless mode, you'll have to modify the program using its API (I guess you use a program like ConsolePhotoGenerator).
