United States
Modifying dimensions once after they have been added
I am using Sweet Home 3D 64 bit version for Windows. I am able to add dimensions to my floor plan, but after the dimension is added I do not see any option to select and modify or even delete the dimension. How can I accomplish this?
Re: Modifying dimensions once after they have been added
You can modify dimensions only with the mouse. If you want to enter a precise value, type <Enter> when you initially draw it. See included help for more information.
Romania
1. Install AdvancedEditingPlugin ; 2. Select dimension (or other thing) then click Resizes all selected items... button.
I use this frequently to insert more accurate dimensions. Also pay attention to position buttons.
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
