Canada/Québec
I need help with a complex roof
I started working on the house roof yesterday. At first, I made the magenta wall on the first floor and dived it so I could make a triangle. But then I wondered: Would I still be able to customize my room?
So today I started over, I made the first floor slop and then added the white triangle on an extra level.
As I thought the pink carry over the other wall and ceiling... I just want the carpeted room to be pink not the rest. So as you see I have no idea how to make my triangular wall.
If you have any question feel free to ask.
I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " "
I'm not 100% happy with this, but it looks better. I'm having a hard time figuring how to my inclined walls look nice...
It still doesn't fit... so I guess I have to make the Cyan higher?
Or edit the part of the first flor that pops out?
Canada/Québec
Re: I need help with a complex roof
Thanx for the tip, I'll study that house file.
Hi Shralen HERE is a zip file that contains 2 projects and some screen shots, hopefully you can use them to help you understand how the roof panels can be made with the shape generator tool and also the way to use rooms to help create your wall colouring's. You will see that some of the walls are joined and some are not. Good luck Mike
Also is there a way to get notified when someone answers our tread/us?
It is far from perfect, but it gives you an idea of what I'm trying to do. I did try the shape generator tool, but since I want my shape to exceed the house it is not that easy. I'm not that good in math so it is getting quite complex to make the roof...
I send Mike53 the .sh3d file, they said they would try to help me. We'll see if we can figure out how to do the rest.
