United States
How do I create a roof over a carport, support posts and no walls?
OK, DAY 1 with this software... How do I create a roof supported with posts and no walls over a carport? All I can figure out is walls. Here is a picture of what I need to do a floor plan for... https://drive.google.com/file/d/14eP0IkvllHro...JhQxhm8I/view?usp=sharing Any guidance would be very appreciated!
Canada/Québec
Re: How do I create a roof over a carport, support posts and no walls?
First, I would add a level. On this 'second' level I would use two triangles to make the Carport main structure. Then use six boxes to make the posts on the ground level.
I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " "
I did this without knowing every measurement.
United States
That is awesome. I have a lot to learn. Including how to know when someone responded to my post here. Just seeing your replies. Would you be willing to send me this file so I could use it as a starting point? If yes, my email is barrydollar@gmail.com Thanks for showing me it can be done!
Canada/Québec
Sure, I'll send the file I had keep it in case you wanted it XD.
As for knowing where someone responds to your post, I suggest you put it in your favorite. Then you can go to your profile and click on 'My Favorite Threads'. From there you can see if someone had answered. Also, I have no idea if there is an easier way to see if someone answers a thread. I'm still new to the forum.
