Re: 3D rotation of an Object
You can’t rotate an object around 3 axes in Sweet Home 3D, except in the 2nd step of the import wizard.
Romania
Is it possible ?
Yes. Select the object after insert in plan; Right click->modify furniture->set the rotation angle on 3 axis. Will don't work until You selected again after insertion.
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
Yes,thanks, i tried but it is pretty dufficult to pick the right angle, rotation 3d, and furthermore once i change the angle it goes in totaly wrong position. Maybe i have to select it again as you suggest... Would the below help to draw the roof of my attic ? http://www.sweethome3d.com/support/forum/viewthread_thread,6600_offset,0
Romania
For simple roofs could help but for some little more complex don't. Especially if you want to insert some windows or an unregulated shape of roof. Is not quite a simple task but with perseverance You will succeed. Sometime You need to elevate more than necessary to be able to rotate, then set the correct elevation and orientation.
Do it like Puybaret wrote: reimport your roof and turn it to the position you need in the 2nd step of the import wizard.
Pascal
