Total posts in this thread: 4
Previous Thread This topic has been viewed 3830 times and has 3 replies Next Thread
SamM319
Canada
Trying to create an all-white background
Hi, I am trying to render a 3d image of a building but i would like the ground and the entire background to be white (basically anything that isn't part of the actual building itself). I have tried using a white floor, and a user imported texture that is just a blank white image. In the 3d view, the ground and background are white, exactly how i want the image to look but when i render it to a photo, it looks sort of grey/blue. I've tried changing any settings that i think are relevant and haven't found anything useful in the forum yet. Any tips?
[Dec 22, 2020, 9:50:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Trying to create an all-white background
You may get a more pure white if you render the image at midday in the summer.
[Dec 25, 2020, 6:05:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi SamM319
To get an even white background, you have to use a backdrop:
Cover the ground and the sky with a white object that emits a white light [mtl: illum=0 ](check my project file).
Here is what it will look like in sunshine:
and here is what it will look like with sky lighting (IBL) enabled :
And here is my project file:
Demo-backdrop.sh3d
Check out my settings, and you (or anyone) are welcome to use my white backdrop as you please.
Hope this helps.
Cecilia
[Edit 1 times, last edit by Ceciliabr at Dec 28, 2020, 7:58:53 PM]
[Dec 28, 2020, 7:46:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lucco.cl
applause Re: Trying to create an all-white background
Just PERFECT! Thanks Cecilia
:-D
[Sep 1, 2023, 12:08:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
