United States
Creating a simple 1" x 4" wall trim
Hi all - Just bought SH3D and have been using it for a couple of days now, but I just can not find a way to add a simple [wood] trim (1" x 4" wall) to rooms that can be also used along the floors as baseboard (1" x 6").
I'd need to be able to adjust the trim's distance from the ceiling (i.e. dropped about a foot from the top) as well as adjusting the depth (i.e., how far it protrudes out from the wall). I would think that'd be a simple polygonal shape with parameter tweaks but I can't find that anywhere in the models or features. Here is the wood trim look I'm talking about...
Canada/Québec
Re: Creating a simple 1" x 4" wall trim
In your SH3D you should have a piece of furniture called Box, select that and drag it in your project. Then you can change the size and height to fit your room.
For baseboard, click on the wall you want to add a baseboard, then go to 'modify baseboard' then modify as you'd like.
In case the image broke: https://sta.sh/025aj598pp2k
I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " "
