Hi, after creating a model with some levels, on 3D view I've found the floor shadow on the ceiling.
Here the some examples:
And my levels:
How can I solve the problem? Thanks to all!
[Note from moderator: fixed links to images, be sure to use "Direct Link" option]
[Edit 1 times,
last edit by Puybaret at Jan 6, 2021, 4:25:38 PM]
Re: Floor shadow on the ceiling
This must be the ceiling of some rooms. The height of a level is used to compute the elevation of ceilings and you should enter the height of the level, not the altitude of the ceilings. So I guess the last column of your level modification dialog box should rather display 320.
