America
Unable to run Sweet Home 3D in OpenBSD
All,
When attempting to run Sweet Home 3D in OpenBSD (with OpenJDK installed), SH3D returns the following.
$ ./SweetHome3D : not foundin/java[4]: � : not foundin/java[4]: � : not foundin/java[4]: � ./runtime/bin/java[4]: : not found ./runtime/bin/java[4]: H��H���52 : not found ./runtime/bin/java[4]: H��t��H�ÐU�8: not found ]�8: not foundjava[4]: H��t�H��t ./runtime/bin/java[4]: UH��8: not found ./runtime/bin/java: syntax error: `)' unexpected safesecs$ ./SweetHome3D-Java3D-1_5_2 : not foundin/java[4]: � : not foundin/java[4]: � : not foundin/java[4]: � ./runtime/bin/java[4]: : not found ./runtime/bin/java[4]: H��H���52 : not found ./runtime/bin/java[4]: H��t��H�ÐU�8: not found ]�8: not foundjava[4]: H��t�H��t ./runtime/bin/java[4]: UH��8: not found ./runtime/bin/java: syntax error: `)' unexpected
$ java -version openjdk version "1.8.0_265" OpenJDK Runtime Environment (build 1.8.0_265-b01) OpenJDK 64-Bit Server VM (build 25.265-b01, mixed mode)
America
Re: Unable to run Sweet Home 3D in OpenBSD
Puybaret,
Thank you. One step closer. The Sweet Home splash screen pops up, however, the application never fully starts.
The following is displayed in the terminal.
Exception in thread "main" java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at com.eteks.sweethome3d.SweetHome3DBootstrap.main(Unknown Source) Caused by: java.lang.ExceptionInInitializerError at com.jogamp.opengl.GLProfile.<clinit>(GLProfile.java:154) at jogamp.opengl.ThreadingImpl$1.run(ThreadingImpl.java:83) at jogamp.opengl.ThreadingImpl$1.run(ThreadingImpl.java:66) at java.security.AccessController.doPrivileged(Native Method) at jogamp.opengl.ThreadingImpl.<clinit>(ThreadingImpl.java:66) at com.jogamp.opengl.Threading.disableSingleThreading(Threading.java:164) at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:129) at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267) at javax.media.j3d.GraphicsConfigTemplate3D.isGraphicsConfigSupported(GraphicsConfigTemplate3D.java:348 ) at com.eteks.sweethome3d.j3d.Component3DManager.createGraphicsConfigurationTemplate3D(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source) ... 5 more Caused by: java.lang.RuntimeException: Please port OS detection to your platform (openbsd/null) at jogamp.common.os.PlatformPropsImpl.getOSTypeImpl(PlatformPropsImpl.java:523) at jogamp.common.os.PlatformPropsImpl.<clinit>(PlatformPropsImpl.java:166) ... 22 more
America
Puybaret,
Receive the same initial error. No splash screen.
Sorry, I don't have any other idea. There are so many Linux variants out there that when you add to them the potential issues coming their 3D drivers, it becomes impossible to ensure that Sweet Home 3D can work on each of them.
