You only need a HTTP server like Apache. But you can also use Tomcat, since it handles also requests to static content.
First, download
source code of the latest version.
Then, from the
README.TXT file it contains, you'll have to:
- download and install last
JDK 6,
Ant,
- run the following Java command in the directory where you uncompressed the archive of the source code:
keytool -genkey -keystore keys.keytool -alias SweetHome3D
(keytool is a command of the JDK, if system doesn't recognize keytool, give the full path of keytool or change system PATH)
- run "ant" command in the directory where you uncompressed the archive of the source code. The default
javaWebStart target will create signed jars in deploy/lib subdirectory.
- edit
deploy/SweetHome3D.jnlp file and change the value of the
codebase attribute at line 3 to the URL base where you want to host your version of Sweet Home 3D.
- upload the content of deploy directory on your server in a directory matching this URL base.
Your Java Web Start version of Sweet Home 3D is ready.
