Re: screen / font size to small to used
Please read the FAQTexts in the furniture catalog are not displayed correctly or icons in the toolbar appear very small on my computer. How can I fix that?
India
Can you please, let me know how to use the suggested method in the FAQ... that is HiDPI Java Web Start version???
I'm running Windows 10 64X on a PC I sorted this successfully: Searched C:\ drive for JAVA.EXE Results beside SweetHome logo caame up with multiple versions of JAVA.EXE, JAVAW.EXE & JAVAWS.EXE I opened each in turn and applied the following:
Find java.exe you installed. - (You've just done this) Right click -> Properties Go to Compatibility tab Check Override high DPI scaling behaviour. Choose 'System' in the 'Scaling performed by:' Check 'Apply' to each in turn.
Do this for all of the above 'exe' files Restart the computer Open SweetHome and I hope you find the issue resolved.
I don't know if all of them needed modifying but doing so worked for me. :) :) :)
