Total posts in this thread: 15
Posts: 15   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 3829 times and has 14 replies Next Thread
dorin
Romania
Re: Error 3D rendering
Don't jump directly to point 4.
Continue reading the sub-points 4.1 and 4.2.
I've assume you know how to run an executable file (script) under linux.
If don't, you will have to learn or finally ask again for help.
Anyway stop using the SH3D repository version under any kind of linux.
[Mar 4, 2024, 5:27:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Mike_Engl
Spain
Hello,
Same problem here: "SH3D will exit now because of a fatal error in the 3D rendering system. Please update DirectX/OpenGL drivers of your graphics card"
I have the latest version of all drivers. Windows 11 Pro fully updated, Nvidia 3080ti with latest drivers (551.76) and the program don't want to start.
Any ideas? Thank you
[Mar 17, 2024, 6:10:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
herman909k
NL
Followed a recommendation, run in terminal. May be it gives some clues.
HPZ4Tumbleweed:/opt/SweetHome3D-7.3 # ./SweetHome3D123
com.jogamp.opengl.GLException: J3D-Renderer-1: Error making temp context(1) current: display 0x7f12dc14a890, context 0x7f12dc2f5818, drawable X11OnscreenGLXDrawable[Realized true,
Factory jogamp.opengl.x11.glx.X11GLXDrawableFactory@70b22d09,
Handle 0x2d0008b,
Surface JAWTWindow[0x7e1d34b6][JVM version: 1.8.0_202 (1.8.0 update 202)
JAWT version: 0x10004, CA_LAYER: false, isLayeredSurface false, bounds [ 0 / 0 731 x 506 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], pixelScale 1.0x1.0, shallUseOffscreenLayer false, isOffscreenLayerSurface false, attachedSurfaceLayer 0x0, windowHandle 0x2d0008b, surfaceHandle 0x2d0008b, bounds [ 0 / 0 731 x 506 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], window [0/0 731x506], pixels[scale 1.0, 1.0 -> 731x506], visible true, lockedExt false,
config AWTGraphicsConfiguration[AWTGraphicsScreen[AWTGraphicsDevice[type .awt, connection :0.0, unitID 0, awtDevice X11GraphicsDevice[screen=0], handle 0x0], idx 0],
chosen GLCaps[glx vid 0x28, fbc 0xdf: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
X11GraphicsConfig[dev=X11GraphicsDevice[screen=0],vis=0x28],
encapsulated X11GLXGraphicsConfiguration[X11GraphicsScreen[X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x7f12dc14a890, owner true, JAWTToolkitLock[obj 0x3cadeeb5, isOwner true, <5342b4a6, 32f911a2>[count 1, qsz 0, owner <J3D-Renderer-1>]]], idx 0], visualID 0x28, fbConfigID 0xdf,
chosen GLCaps[glx vid 0x28, fbc 0xdf: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]]]],
awtComponent com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas2,0,0,731x506],
surfaceLock <640cdfc1, 99317f6>[count 1, qsz 0, owner <J3D-Renderer-1>]]]
at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:393)
at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:794)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:677)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:615)
at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6411)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4612)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2386)
at javax.media.j3d.Renderer.doWork(Renderer.java:881)
at javax.media.j3d.J3dThread.run(J3dThread.java:271)
Error in Java 3D : 3 Renderer: Error creating Canvas3D graphics contextX11Util.Display: Shutdown (JVM shutdown: true, open (no close attempt): 2/2, reusable (open, marked uncloseable): 0, pending (open in creation order): 2)
X11Util: Open X11 Display Connections: 2
X11Util: Open[0]: NamedX11Display[:0, 0x7f12dc02ad20, refCount 1, unCloseable false]
X11Util: Open[1]: NamedX11Display[:0, 0x7f12dc14a890, refCount 1, unCloseable false]
[Apr 24, 2024, 12:12:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
herman909k
NL
Add: system is Suse Tumbleweed, NVIDIA Quatro M4000, all drivers up to date. Using the Java openjdk version 11.0.23 gives these kind of errors too.
[Apr 25, 2024, 7:36:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
1. Why you've installed under /opt which is under root system?
2. Why you run it as root?
2.1 This is not recommended to do for any applications which usually have to run by a user!
2.2 Particularly for SH3D is that will create the .eteks properties folder under root and not under /home/[user-name]/ if you run it as root.
3. I don't know from where you have "SweetHome3D123" file and what is inside. It should be only "SweetHome3D".
4. There have to be also "SweetHome3D-Java3D-1_5_2" file.
Try to run with this file.
5. If you follow STRICTLY the steps described in user's guide this files need to start SH3D by double click on them.
[Apr 25, 2024, 8:03:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
