FR
building SWJS
Hi all
I've been trying to build the SWJS project for about 10 hours but without success. I gave up the idea to build it under windows and installed an Ubuntu image.
transpiledLibraries: [javac] /home/toto/TEST/SweetHome3DJS-7.1-src/build.xml:32: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds [java] INFO: JSweet transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2023-04-15 03:26:38.038 INFO JSweetCommandLineLauncher:682 - input dirs: [../SweetHome3D/src, tools/JSweet/src] [java] 2023-04-15 03:26:38.038 INFO JSweetCommandLineLauncher:694 - classpath: null [java] 2023-04-15 03:26:38.038 INFO JSweetCommandLineLauncher:709 - included: [def.*, com/eteks/sweethome3d/model.*, com/eteks/sweethome3d/tools.*, com/eteks/sweethome3d/viewcontroller.*, com/eteks/sweethome3d/io.*] [java] 2023-04-15 03:26:38.038 INFO JSweetCommandLineLauncher:710 - excluded: [] [java] 2023-04-15 03:26:38.038 INFO JSweetCommandLineLauncher:715 - add sources from directory: ../SweetHome3D/src [java] 2023-04-15 03:26:38.038 INFO JSweetCommandLineLauncher:715 - add sources from directory: tools/JSweet/src [java] 2023-04-15 03:26:38.038 INFO JSweetCommandLineLauncher:760 - ts output dir: tools/JSweet/build/ts [java] 2023-04-15 03:26:38.038 INFO JSweetCommandLineLauncher:767 - js output dir: tools/JSweet/build/js [java] 2023-04-15 03:26:38.038 INFO JSweetTranspiler:423 - no configuration file found at /home/toto/TEST/SweetHome3DJS-7.1-src/./jsweetconfig.json [java] 2023-04-15 03:26:38.038 INFO JSweetTranspiler:528 - creating transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2023-04-15 03:26:38.038 INFO JSweetTranspiler:530 - current dir: /home/toto/TEST/SweetHome3DJS-7.1-src/. [java] 2023-04-15 03:26:38.038 INFO JSweetTranspiler:531 - base directory: /home/toto/TEST/SweetHome3DJS-7.1-src/. [java] 2023-04-15 03:26:38.038 INFO JSweetTranspiler:532 - working directory: /home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/jsweet.tmp [java] 2023-04-15 03:26:38.038 INFO JSweetTranspiler:533 - tsOut: tools/JSweet/build/ts - /home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/ts [java] 2023-04-15 03:26:38.038 INFO JSweetTranspiler:534 - jsOut: tools/JSweet/build/ts - /home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/ts [java] 2023-04-15 03:26:38.038 INFO JSweetTranspiler:535 - candyJsOut: tools/JSweet/build/js [java] 2023-04-15 03:26:38.038 INFO JSweetTranspiler:536 - factory: com.eteks.sweethome3d.jsweet.SweetHome3DJSweetFactory@5f150435 [java] 2023-04-15 03:26:38.038 INFO CandyProcessor:123 - candies processor classpath: /home/toto/TEST/SweetHome3DJS-7.1-src/./jsweet_extension:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/bigjs-3.1.0-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-awtgeom-1.8.132-20200519.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-batik-svgpathparser-1.10.0-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-swingundo-1.8.132-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/jsweet-core-6.3.1.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/SweetHome3DJSweetExtension [java] 2023-04-15 03:26:38.038 INFO CandyProcessor:141 - extracted candies directory: tools/JSweet/build/js [java] 2023-04-15 03:26:38.038 INFO JSweetCommandLineLauncher:891 - definition input dirs: [] [java] 2023-04-15 03:26:38.038 INFO ProcessUtil:138 - cannot find tsc - searching in /home/toto/.jsweet.v3-node_modules [java] 2023-04-15 03:26:38.038 INFO CandyProcessor:226 - 6 candies found in classpath [java] 2023-04-15 03:26:38.038 INFO CandyProcessor:163 - candies are up to date [java] fatal error in transpiler [java] java.lang.ExceptionInInitializerError [java] at org.jsweet.transpiler.JSweetContext.<init>(JSweetContext.java:730) [java] at org.jsweet.transpiler.JSweetFactory.createContext(JSweetFactory.java:39) [java] at org.jsweet.transpiler.JSweetTranspiler.prepareForJavaFiles(JSweetTranspiler.java:715) [java] at org.jsweet.transpiler.JSweetTranspiler.java2ts(JSweetTranspiler.java:885) [java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:836) [java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897) [java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272) [java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240) [java] Caused by: java.lang.RuntimeException: Fatal error - cannot access legacy Javac API [java] at org.jsweet.transpiler.util.Util.<clinit>(Util.java:2526) [java] ... 8 more [java] Caused by: java.lang.reflect.InaccessibleObjectException: Unable to make field public com.sun.tools.javac.code.Type com.sun.tools.javac.tree.JCTree.type accessible: module jdk.compiler does not "exports com.sun.tools.javac.tree" to unnamed module @336eb6ed [java] at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:354) [java] at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:297) [java] at java.base/java.lang.reflect.Field.checkCanSetAccessible(Field.java:178) [java] at java.base/java.lang.reflect.Field.setAccessible(Field.java:172) [java] at org.jsweet.transpiler.util.Util.<clinit>(Util.java:2522) [java] ... 8 more
BUILD FAILED /home/toto/TEST/SweetHome3DJS-7.1-src/build.xml:81: The following error occurred while executing this line: /home/toto/TEST/SweetHome3DJS-7.1-src/build.xml:37: Java returned: 255
transpiledLibraries: [javac] /home/toto/TEST/SweetHome3DJS-7.1-src/build.xml:32: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds [java] INFO: JSweet transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2023-04-15 20:02:25.025 INFO JSweetCommandLineLauncher:682 - input dirs: [../SweetHome3D/src, tools/JSweet/src] [java] 2023-04-15 20:02:25.025 INFO JSweetCommandLineLauncher:694 - classpath: null [java] 2023-04-15 20:02:25.025 INFO JSweetCommandLineLauncher:709 - included: [def.*, com/eteks/sweethome3d/model.*, com/eteks/sweethome3d/tools.*, com/eteks/sweethome3d/viewcontroller.*, com/eteks/sweethome3d/io.*] [java] 2023-04-15 20:02:25.025 INFO JSweetCommandLineLauncher:710 - excluded: [] [java] 2023-04-15 20:02:25.025 INFO JSweetCommandLineLauncher:715 - add sources from directory: ../SweetHome3D/src [java] 2023-04-15 20:02:25.025 INFO JSweetCommandLineLauncher:715 - add sources from directory: tools/JSweet/src [java] 2023-04-15 20:02:25.025 INFO JSweetCommandLineLauncher:760 - ts output dir: tools/JSweet/build/ts [java] 2023-04-15 20:02:25.025 INFO JSweetCommandLineLauncher:767 - js output dir: tools/JSweet/build/js [java] 2023-04-15 20:02:25.025 INFO JSweetTranspiler:423 - no configuration file found at /home/toto/TEST/SweetHome3DJS-7.1-src/./jsweetconfig.json [java] 2023-04-15 20:02:25.025 INFO JSweetTranspiler:528 - creating transpiler version 3.2.0-SNAPSHOT (build date: 2021-07-28 14:35:21) [java] 2023-04-15 20:02:25.025 INFO JSweetTranspiler:530 - current dir: /home/toto/TEST/SweetHome3DJS-7.1-src/. [java] 2023-04-15 20:02:25.025 INFO JSweetTranspiler:531 - base directory: /home/toto/TEST/SweetHome3DJS-7.1-src/. [java] 2023-04-15 20:02:25.025 INFO JSweetTranspiler:532 - working directory: /home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/jsweet.tmp [java] 2023-04-15 20:02:25.025 INFO JSweetTranspiler:533 - tsOut: tools/JSweet/build/ts - /home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/ts [java] 2023-04-15 20:02:25.025 INFO JSweetTranspiler:534 - jsOut: tools/JSweet/build/ts - /home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/ts [java] 2023-04-15 20:02:25.025 INFO JSweetTranspiler:535 - candyJsOut: tools/JSweet/build/js [java] 2023-04-15 20:02:25.025 INFO JSweetTranspiler:536 - factory: com.eteks.sweethome3d.jsweet.SweetHome3DJSweetFactory@614c5515 [java] 2023-04-15 20:02:25.025 INFO CandyProcessor:123 - candies processor classpath: /home/toto/TEST/SweetHome3DJS-7.1-src/./jsweet_extension:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/bigjs-3.1.0-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-awtgeom-1.8.132-20200519.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-batik-svgpathparser-1.10.0-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-swingundo-1.8.132-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/jsweet-core-6.3.1.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/SweetHome3DJSweetExtension [java] 2023-04-15 20:02:25.025 INFO CandyProcessor:141 - extracted candies directory: tools/JSweet/build/js [java] 2023-04-15 20:02:25.025 INFO JSweetCommandLineLauncher:891 - definition input dirs: [] [java] 2023-04-15 20:02:25.025 INFO ProcessUtil:138 - cannot find tsc - searching in /home/toto/.jsweet.v3-node_modules [java] WARNING: An illegal reflective access operation has occurred [java] WARNING: Illegal reflective access by org.jsweet.transpiler.util.Util (file:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar) to field com.sun.tools.javac.tree.JCTree.type [java] WARNING: Please consider reporting this to the maintainers of org.jsweet.transpiler.util.Util [java] WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations [java] WARNING: All illegal access operations will be denied in a future release [java] 2023-04-15 20:02:25.025 INFO CandyProcessor:226 - 6 candies found in classpath [java] 2023-04-15 20:02:25.025 INFO CandyProcessor:163 - candies are up to date [java] 2023-04-15 20:02:25.025 INFO JavaCompilationComponents:122 - creating JavaCompiler task with options: JavaCompilerOptions: [--module-path, /home/toto/TEST/SweetHome3DJS-7.1-src/./jsweet_extension:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/bigjs-3.1.0-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-awtgeom-1.8.132-20200519.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-batik-svgpathparser-1.10.0-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-swingundo-1.8.132-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/jsweet-core-6.3.1.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/SweetHome3DJSweetExtension, -cp, /home/toto/TEST/SweetHome3DJS-7.1-src/./jsweet_extension:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/jsweet-transpiler-3.2.0-SNAPSHOT-jar-with-dependencies.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/bigjs-3.1.0-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-awtgeom-1.8.132-20200519.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-batik-svgpathparser-1.10.0-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/j4ts-swingundo-1.8.132-20170726.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/lib/jsweet-core-6.3.1.jar:/home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/SweetHome3DJSweetExtension, -Xlint:path, -encoding, ISO-8859-1] [java] 2023-04-15 20:02:26.026 INFO JSweetTranspiler:1170 - creating bundle file: tools/JSweet/build/ts/bundle.ts [java] 2023-04-15 20:02:26.026 INFO JSweetTranspiler:1227 - created tools/JSweet/build/ts/bundle.ts [java] 2023-04-15 20:02:26.026 INFO JSweetTranspiler:1145 - scanning tools/JSweet/src/def/sweethome3d/SweetHome3D.java... [java] 2023-04-15 20:02:26.026 INFO JSweetTranspiler:1145 - scanning tools/JSweet/src/def/sweethome3d/SAXParser.java... [java] 2023-04-15 20:02:26.026 INFO JSweetTranspiler:1145 - scanning tools/JSweet/src/def/sweethome3d/Scene3D.java... [java] 2023-04-15 20:02:26.026 INFO JSweetTranspiler:1145 - scanning tools/JSweet/src/def/sweethome3d/Core.java... [java] 2023-04-15 20:02:26.026 INFO JSweetTranspiler:1170 - creating bundle file: tools/JSweet/build/ts/bundle.d.ts [java] 2023-04-15 20:02:26.026 INFO JSweetTranspiler:1227 - created tools/JSweet/build/ts/bundle.d.ts [java] 2023-04-15 20:02:26.026 INFO JSweetTranspiler:865 - ts2js on org.jsweet.transpiler.TypeScript2JavaScriptWithTscTranspiler@36546a22 sourceFiles=4 [java] 2023-04-15 20:02:26.026 INFO TypeScript2JavaScriptWithTscTranspiler:84 - launching tsc... [java] 2023-04-15 20:02:26.026 INFO ProcessUtil:138 - cannot find tsc - searching in /home/toto/.jsweet.v3-node_modules [java] 2023-04-15 20:02:27.027 INFO JSweetTranspiler:849 - transpilation process finished in 1388 ms [java] > java2ts: 405.615265ms [java] > ts2js: 940.755917ms [java] [java] INFO: transpilation successfully completed with no errors and no warnings
BUILD FAILED /home/toto/TEST/SweetHome3DJS-7.1-src/build.xml:85: Warning: Could not find file /home/toto/TEST/SweetHome3DJS-7.1-src/tools/JSweet/build/js/bundle.js to copy.
Re: building SWJS
I’m a macOS user. Not sure I tried to build SweetHome3D JS on Linux once, but sure I tried under Windows. Anyway, this seems to be just a PATH problem.
FR
Re: building SWJS
So I try again on Windows and it works fine. By reading build.xml I understood that the folders structure must be : \TEST\SweetHome3DJS \TEST\SweetHome3D
et not the one I had : \TEST\SweetHome3DJS-7.1-src \TEST\SweetHome3D-7.1-src
