Re: Installing 3d content
One feature not mentioned in the guide is that you can drag-and-drop an object file from a file browser into the Sweethome3D 2D window to import it. This is the method I always use instead of the import through the menu because it's easier and faster and most important: you can drop at the position you want and avoid the default 0,0 position. Another advantage is that you can select multiple object files and drag them all at once into the 2D window. For each file you get the import wizard and all at the position where you drop them. Works perfectly! Unfortunately this method doesn't work with furniture libraries (.sh3f files) but maybe that will be fixed in a future version.
[May 25, 2023, 7:37:21 AM]
[Link]
