Total posts in this thread: 5
Previous Thread This topic has been viewed 1273 times and has 4 replies Next Thread
Abchillen
Germany
Help version 6.6 to 7.1 update or installation
Hello everyone :-)
Please help, I have Linux Ubuntu 22 on my system.
I currently have SweetHome3D version 6.6a installed, but I can neither update nor get the current version 7.1 (tgz) installed.
Can I update?
Or can someone help me how to install a tgz file with instructions?
Thanks.
[Jul 25, 2023, 9:05:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Help version 6.6 to 7.1 update or installation
It might be helpful if you explained what you tried and/or why you can't get it installed.
Have you tried the Linux installer?
https://sourceforge.net/projects/sweethome3d/....1-linux-x64.tgz/download
Otherwise here are step-by-step instructions for Ubuntu 22.04: https://tutorialforlinux.com/2023/02/18/sweet...nstallation-step-by-step/
[Jul 25, 2023, 10:14:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's a long time sine I last used Ubuntu. It used to be very easy to install SH3D (just unpack in a directory of your choice), but after a few updates it was almost impossible to update a program if it's not in the repository/appshop. Reason why I switched back to W10.
You need to find the (hidden) directories where SH3D is installed. Search for the executable of SH3D and replace that with the new one. As far as I remember that should be enough.
[Edit 1 times, last edit by hansmex at Jul 25, 2023, 11:02:25 AM]
[Jul 25, 2023, 10:59:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I'm on Debian on which Ubuntu is based. I'm not sure if this means it's exactly the same on Ubuntu but I just extract the tgz in a directory I want and change the menu command to point to the new SweetHome3D-Java3D-1_5_2 script. Has worked for several new versions so far.
[Jul 25, 2023, 11:07:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe this subject indicated in download page will help.
[Jul 25, 2023, 11:52:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
