Hello I have just updated to version 7.2 (from 7.1) and now when I try to render my scene with Yafaray, the render window goes white with a red cross in the center. Sometimes, SweetHome3D crashes completely. I was rendering the same scene this morning, before updating, and there were no problems at all. Actually, Yafaray has been great for the last two weeks or so, since I started using Sweethome3D again. Does anyone have any ideas on this? Thanks
Re: Yafaray render fails with version 7.2
You probably installed the 32 bit version of Sweet Home 3D. Run the installer again and select 64 bit architecture if possible.
Hello Emmanuel. Thanks for your reply. Uninstalled then reinstalled 64bit version. All working perfectly again now. Many thanks for your help. Love using this software. Michael
