Total posts in this thread: 8
Previous Thread This topic has been viewed 456 times and has 7 replies Next Thread
crackwood01
Canada
Help with rendering
i'm getting rendering problems, is there something i can do
the door looks gray and the quality looks blured
config:
AMD Ryzen 5 5600g
windows 11 pro
x64
32gb ram
gpu g-force rtx 3060 12gb vram
[Nov 21, 2023, 6:56:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
DigitAle.Com
Italia
Re: Help with rendering
hello, since I often have the same problem, but I'm not an expert in SH3D, I'm using the workaround to waste some time to perform tests adding light sources, not visible but It resolves the problem of greysh stuff. I mean waste of time to find a good position and the right percentage of light setting...
I don't think SH3D is using GPU acceleration, (not in my case) just be sure to use the 64 bit release (asked while installing the app.
Then use a higher resolution while rendering, 1280 or 1600 x ...
It takes time... I know. I use YafaRay rendering engine at 4th quality level, then go for a beer, a sandwich or a cigarette... SunFlow seems to be slower to me and creating unwanted white shiny bubbles... but agan, wait for expert users answers. Good Luck.
Alessandro
[Nov 22, 2023, 2:42:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I can see two problems:
1 - the door - this seems to be a Sketchup model. When not all faces are textured, SH3D has problems similar to what we see. Make sure (using Sketchup) that your model has textures on all faces (inside and out) before exporting the model.
2 - black spots in ceiling lights - this is caused by light bulbs touching the ceiling. Lower the light bulbs and the black spots disappear.
[Nov 22, 2023, 6:23:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
Thanks for the reply,
I will give it a try
[Nov 22, 2023, 10:39:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
About the door, you could also make invisible the materials of the inner faces of the furniture (must be the materials named "material").
[Nov 23, 2023, 9:58:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
thank you all,
worked perfectly ;)
[Nov 24, 2023, 1:14:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
[Nov 24, 2023, 1:46:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
DAMN!!! That's a nice jump in quality. applause
[Nov 24, 2023, 2:20:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
