Hello, I have the following problem. I create a project of my flat, and of course as any other flat i have inner walls which are thiner than the outher walls of the building. And of course my inner walls inside the flat cross outer walls. I don't get how can I make those walls merge, they simply lie on on top of another and collide. This makes the project look bad and ruins all the dragging / resizing. I looked in the docs and watched a couple of tutorials but I can't find an answer. Could some1 help? I leave a link to pasteboard to share how my project looks like.
Re: Join walls with different thickness
Make the length of the thin walls smaller, or use the same pattern as the one you used for thicker walls.
