Total posts in this thread: 57
Posts: 57   Pages: 6   [ Previous Page | 1 2 3 4 5 6 | Next Page ]
Previous Thread This topic has been viewed 133028 times and has 56 replies Next Thread
Re: Sweet Home 3D 2.3
Emmanuel:
After a quirky start with Windows Vista (maybe you have seen my deleted post) everything in v2.3b15 seems to work fine on both my computers.
I'm busy updating the English manual and hope to provide a "serious" first draugth (a beta version) pretty soon.
One suggestion for the menu structure: move Plan -> Export to SVG format to 3D view -> Export to SVG format. It seems more logical to have them together. Or else, maybe, you could create a new menu item called Tools or Extra (as in Windows) where you put all the extra tools together.
[Edit 1 times, last edit by hansmex at Feb 24, 2010, 2:30:13 PM]
[Feb 24, 2010, 2:28:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
I found a bug (I think).
v2.3b15
When I tried the create photo, the quick one and the one after that worked but the Best and the next to best did not. It (the rendering area) was just black.
[Feb 25, 2010, 9:49:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The.camera was probably in a wall, and with the two best quality renderers, this will make a black image.
[Feb 25, 2010, 10:58:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
biggrin Re: Sweet Home 3D 2.3
ok, I'll try that. Thanks for the explanation. :) biggrin
[Feb 26, 2010, 3:45:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
High.G
Qatar
this program is realy good now i can improve my skills in housemaking ^_^
thank u sooo much
[Mar 4, 2010, 5:09:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
brill
I just tried to seperate the 3D view on Linux.
The 3D view disappeared form the Main View but there was no separate Windows.
(I'm right now using Ubuntu 9.10 with KDE)
Cheers Brill
[Mar 5, 2010, 7:59:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Would you have any log or stack trace to report, please?
[Mar 5, 2010, 11:28:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
brill
Hi Puybaret,
How can I get stack trace from this Java Webstart?
Cheers Brill
[Mar 5, 2010, 8:36:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
brill
Hello Puybaret,
here is my Stactrace:
Java Web Start 1.6.0_15
Verwendung der JRE-Version 1.6.0_15-b03 Java HotSpot(TM) Client VM
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: adding a container to a container on a different GraphicsDevice
at java.awt.Component.checkGD(Component.java:1099)
at java.awt.Container.checkGD(Container.java:1105)
at java.awt.Container.addImpl(Container.java:1041)
at javax.swing.JLayeredPane.addImpl(JLayeredPane.java:212)
at java.awt.Container.add(Container.java:927)
at javax.swing.JRootPane.setContentPane(JRootPane.java:608)
at javax.swing.JDialog.setContentPane(JDialog.java:997)
at com.eteks.sweethome3d.swing.HomePane.detachView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.detachView(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane$1.actionPerformed(Unknown Source)
at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:272)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
[Mar 8, 2010, 8:52:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you brill for this stack trace. It should help me to fix the bug.
Do you have two screens?
[Mar 8, 2010, 10:37:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
