Posts: 24   Pages: 3   [ Previous Page | 1 2 3 ]
Previous Thread This topic has been viewed 4074 times and has 23 replies Next Thread
Daniel_C
Deutschland
Re: Sweet Home 3D 7.3
Hi, installed the new version 7.3 today on my Mac Mini M2 Pro, but it crashes instantly. Previous versions worked well.
Crash report says, that some "Code 1 Library" is missing...
Translated Report (Full Report Below)
Process: SweetHome3D [1230]
Path: /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D
Identifier: com.eteks.sweethome3d.SweetHome3D
Version: 7.3 (7300)
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2024-04-08 12:44:42.2440 +0200
OS Version: macOS 14.4.1 (23E224)
Report Version: 12
Anonymous UUID: C2EE1AD6-4813-E6A0-DF7E-C476B04B0D7F
Time Awake Since Boot: 770 seconds
System Integrity Protection: enabled
Notes:
PC register does not match crashing frame (0x0 vs 0x10001CA78)
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace DYLD, Code 1 Library missing
Library not loaded: /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher
Referenced from: <DB4461F7-56F8-5BE2-25DE-0B22B179E73D> /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D
Reason: tried: '/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file), '/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file, not in dyld cache), '/Library/Frameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file), '/System/Library/Frameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file, not in dyld cache)
(terminated at launch; ignore backtrace)
Error Formulating Crash Report:
[Apr 8, 2024, 11:52:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did it work with version 7.2 too?
[Apr 8, 2024, 3:26:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniel_C
Deutschland
Found the reason. Sorry, it was my fault: I installed the wrong MAC version (SweetHome3D-7.3-macosx-10.4-10.9.dmg) instead of appropriate (SweetHome3D-7.3-macosx.dmg) for my MacOS 14.4.1 machine by simply clicking the green SourceForge download button.
By the way: Are there any plans to provide a native Apple Silicon arm64 build?
[Apr 8, 2024, 7:57:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's already the case. The application in SweetHome3D-7.3-macosx.dmg is for Intel and Apple Silicon.
[Apr 8, 2024, 9:16:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
