Daniel_C
Deutschland
Re: Sweet Home 3D 7.3
Hi, installed the new version 7.3 today on my Mac Mini M2 Pro, but it crashes instantly. Previous versions worked well.
Crash report says, that some "Code 1 Library" is missing...
------------------------------------- Translated Report (Full Report Below) -------------------------------------
Process: SweetHome3D [1230] Path: /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D Identifier: com.eteks.sweethome3d.SweetHome3D Version: 7.3 (7300) Code Type: X86-64 (Translated) Parent Process: launchd [1] User ID: 501
Date/Time: 2024-04-08 12:44:42.2440 +0200 OS Version: macOS 14.4.1 (23E224) Report Version: 12 Anonymous UUID: C2EE1AD6-4813-E6A0-DF7E-C476B04B0D7F
Time Awake Since Boot: 770 seconds
System Integrity Protection: enabled
Notes: PC register does not match crashing frame (0x0 vs 0x10001CA78)
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Termination Reason: Namespace DYLD, Code 1 Library missing
Library not loaded: /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher Referenced from: <DB4461F7-56F8-5BE2-25DE-0B22B179E73D> /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D Reason: tried: '/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file), '/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file, not in dyld cache), '/Library/Frameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file), '/System/Library/Frameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher' (no such file, not in dyld cache) (terminated at launch; ignore backtrace)
Error Formulating Crash Report: PC register does not match crashing frame (0x0 vs 0x10001CA78)
[Apr 8, 2024, 11:52:00 AM]
[Link]
