Furniture Library Editor released
This topic has been viewed 3826987 times and has 252 replies
ndorigatti
- Member
- Country: Italia
Hello, i have used version 1.20 of the library a bit on a Mac Osx system (Sierra) with both java 1.6 and 1.8 installed (1.8 as default) and i continue to see in console issue of null pointer exception when clicking. I can use the library for a single operation (add a new 3d model, or rename, or delete). At each operation I have to save, close, reopen and go on, which is very tedious... is there a fix or there will be a fix for this? Do you need further logs/info?
Please post the stack trace that appears in the console, that could be useful.
ndorigatti
- Member
- Country: Italia
Hello,
this is what happens with 1.21 when:
Open the editor, import a 3ds model I already use in my house (and in another library), double click on it in the list of items.
From what i can see, is a problem of the table render, shame on you old swing! [:))]
Code: Select all
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.eteks.furniturelibraryeditor.swing.FurnitureLibraryTable$FurnitureLibraryTableColumnModel$6.getTableCellRendererComponent(Unknown Source)
at javax.swing.JTable$AccessibleJTable.getAccessibleChild(JTable.java:7031)
at javax.swing.JTable$AccessibleJTable.getAccessibleAt(JTable.java:7418)
at javax.swing.JTable$AccessibleJTable.valueChanged(JTable.java:6933)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:184)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:164)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:211)
at javax.swing.DefaultListSelectionModel.changeSelection(DefaultListSelectionModel.java:405)
at javax.swing.DefaultListSelectionModel.changeSelection(DefaultListSelectionModel.java:415)
at javax.swing.DefaultListSelectionModel.setSelectionInterval(DefaultListSelectionModel.java:459)
at javax.swing.JTable.changeSelectionModel(JTable.java:2389)
at javax.swing.JTable.changeSelection(JTable.java:2456)
at javax.swing.plaf.basic.BasicTableUI$Handler.adjustSelection(BasicTableUI.java:1115)
at javax.swing.plaf.basic.BasicTableUI$Handler.mousePressed(BasicTableUI.java:1038)
at javax.swing.plaf.basic.BasicTableUI$MouseInputHandler.mousePressed(BasicTableUI.java:798)
at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:280)
at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:279)
at java.awt.Component.processMouseEvent(Component.java:6532)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6300)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4891)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4713)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4522)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2750)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:154)
at javax.swing.DefaultListSelectionModel.setValueIsAdjusting(DefaultListSelectionModel.java:685)
at javax.swing.plaf.basic.BasicTableUI$Handler.setValueIsAdjusting(BasicTableUI.java:955)
at javax.swing.plaf.basic.BasicTableUI$Handler.mouseReleased(BasicTableUI.java:1166)
at javax.swing.plaf.basic.BasicTableUI$MouseInputHandler.mouseReleased(BasicTableUI.java:802)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:290)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
at java.awt.Component.processMouseEvent(Component.java:6535)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at javax.swing.JTable$AccessibleJTable.getAccessibleAt(JTable.java:6990)
at sun.lwawt.macosx.CAccessibility$23.call(CAccessibility.java:414)
at sun.lwawt.macosx.CAccessibility$23.call(CAccessibility.java:393)
at sun.lwawt.macosx.LWCToolkit$CallableWrapper.run(LWCToolkit.java:597)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:301)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)Re: Furniture Library Editor released
I couldn't reproduce this issue on my side, but maybe I didn't test correctly your "import a 3ds model I already use in my house (and in another library)" suggestion. There should be no difference in how the Furniture Library Editor manages completely unknown 3DS models or the ones you used once in a Sweet Home 3D project. What detail could I have missed?
ndorigatti
- Member
- Country: Italia
Hi, I think I did not explain correctly what the issue is!
The error is not related to what model I use (it was just a specification).
This is an issue with Java, AWT/SWING and OSX Sierra.
The problem is completely UI related, clicks do not work correctly, events duplicated.... I did the same the other day on a Windows 7 machine and it works perfectly.
Currently I'm running java build 1.8.0_91-b14 on OSX 10.12.6
I tryed to force running with the legacy java 1.6 but it did not change anything.
I'm quite sure it is something related to OSX, but can't understand what...
My attempt was made under macOS 10.12.6 with Java 8u144. Maybe it could worth that you try with a more recent Java version?
ndorigatti
- Member
- Country: Italia
Hi, even with 8u144 it gives the issue when double clicking on an imported forniture. Imported 2 forniture and double clicked on one of the two.... Gives the issue.
Is the jar code opensource? Maybe I can try to compile and debug when I have a couple of hours!
I use Windows system for a few days ago, I can't enter the furniture Library Editor's work, I will try to remove all JAVA and install JDK-8u144-Window, OK.
I cant get my new created library to save. I just get an error saying "cant save SH3F file" I have tried changing the name and still wont save.
I also cant open any of the libraries that came with the software. Sweet Home 3D.
I really enjoy this software and I have had it for a Long time, never had the library editor until recently.
Thank you
Thank you
Which operating system do you use ?
Which version of SH3D ?
Who is online
Users browsing this forum: Bing [Bot]
