Features
Total posts in this thread: 17
Posts: 17   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 11450 times and has 16 replies Next Thread
white0demon
Re: error with plug-ins eclipse
Just checking, what are all the properties for the jar export?
[Aug 25, 2010 12:24:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
msk
Have the same problem.
My plugin:
public class TestPlugin extends com.eteks.sweethome3d.plugin.Plugin {
@Override
public PluginAction[] getActions() {
return new PluginAction[]{new TestAction()};
Application output:
Invalid plug-in jar:file:/home/msk/.eteks/sweethome3d/plugins/sh3d_mirror_plugin.jar!/ApplicationPlugin.properties:
msk.test.TestPlugin not a subclass of com.eteks.sweethome3d.plugin.Plugin
[Aug 19, 2014 3:51:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
How do you launch Sweet Home 3D?
Did you check that sh3d_mirror_plugin.jar is the only plug-in in /home/msk/.eteks/sweethome3d/plugins/ folder?
Did you check its date?
[Aug 19, 2014 6:16:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
msk
Yes it is.
I tried to check if it is not a JDK version mismatch problem so I completely removed JDK7, installed JDK6, so my generated class is the same version as (for example) class from "Advanced Editing Plugin" - 32 hex = jdk 1.6.
Plugin still rejected, both on linux(64bit) and windows (64bit). Dunno what to do now ...
[Aug 19, 2014 6:42:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
msk
... I run it from within IDEA ide, using ...Bootstrap... main class, jar is copied manually into plugins folder.
[Aug 19, 2014 6:45:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
msk
OK, it should be a some weird problem within IDE, because I tried to start locally installed sh3d (using windows installer) and plugin was loaded (I see meny entry).
But what to do now. I need to debug the plugin :D ...
[Aug 19, 2014 6:52:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
msk
Yes, it's IDEA problem.
When IDEA is executing project (in debug mode), commandline looks like:
C:\Program Files\Java\jdk1.6.0_38\bin\java" -Dvisualvm.id=4187372098827 -Didea.launcher.port=7536 "-Didea.launcher.bin.path=C:\Program Files (x86)\JetBrains\IntelliJ IDEA 12.0.1\bin" -Dfile.encoding=UTF-8 -classpath "C:\Program Files\Java\jdk1.6.0_38\jre\lib\charsets.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\deploy.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\javaws.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\jce.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\jsse.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\management-agent.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\plugin.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\resources.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\rt.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\ext\dnsns.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\ext\localedata.jar;C:\Program Files\Java\jdk1.6.0_38\jre\lib\ext\sunjce_provider.jar;C:\Program FilesJavajdk1.6.0_38jrelibextsunmscapi.jar;C:Usersmsktmpuntitledoutproductionuntitled;C
:\Users\msk\tmp\untitled\lib\SweetHome3D-4.4.jar;C:\Program Files (x86)\JetBrains\IntelliJ IDEA 12.0.1\lib\idea_rt.jar" com.intellij.rt.execution.application.AppMain com.eteks.sweethome3d.SweetHome3DBootstrap
When I removed all that additional jars and only sh3d.jar remained, plugin was loaded successfully.
I'll try to find which library will break it, maybe some custom classloaders are used there ...
Thx and sry for mistake.
[Aug 19, 2014 7:01:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
