Total posts in this thread: 17
Posts: 17   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 32809 times and has 16 replies Next Thread
db4tech
smile AdancedRenderingMini-1.6.sh3p
Hi all,
Something I was discussing with Emmanuel sparked an idea!
My display resolution is quite low, so it is easy to run out of space.
With that I mind I had the idea of producing a mini interface version of the AdvancedRendering-1.6.sh3p plugin, for people with lower resolutions displays, the size is designed especially so Netbook users can also enjoy the new plugin.
AdancedRenderingMini-1.6.sh3p smile
This image shows a size comparison.
The mini interface is using the same font size, which is more user friendly as it helps people who may have vision problems. To keep the interface as small as possible, I abbreviated some of the option labels.
Everything still works the same, but I will wait for Emmanuel's approval before offering it as a download.
Do hope this will be helpful for users!
db4tech
Edit:
31-08-10 Added the download. (Directly below this text)
Looks a bit lost within the long description I added, Oops!
Attachment AdvancedRenderingMini-1.6.sh3p (106283 bytes) (Download count: 636) (Smaller interface version of AdvancedRendering-1.6.sh3p AdvancedRenderingMini-1.6.sh3p Designed for users with lower resolution displays (Netbook friendly) Plugin to produce a photo realistic renders.)
[Edit 2 times, last edit by db4tech at Aug 31, 2010, 9:28:01 AM]
[Aug 29, 2010, 5:36:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: AdancedRenderingMini-1.6.sh3p
No problem db4tech, go forward! wink
[Aug 29, 2010, 10:08:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
db4tech
Merci Emmanuel, also for your help with the French translations. smile
Would you like me to add it here, or will you be hosting it on the Sweet Home blog page with the full size Advancedrendering-1.6.sh3p plugin so it is easier for users to find?
I've been thinking, since you have a furniture page, what are your thoughts on adding a plugin page, there are some great plug-ins talked about in the forums, but they can be difficult to find once a post becomes old.
I guess they will most likely be in the 'List Attachments' section, although if they had their own page, a nice description and maybe a small image of the interface would be helpful?
Interested to hear your thoughts.
Thank you! smile
db4tech
[Aug 29, 2010, 11:53:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
db4tech, Emmanuel.
The plug-in page is a great idea!
[Aug 29, 2010, 12:06:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I'll have to think about this plug-in page...
[Aug 29, 2010, 4:26:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
whippetsleek
Just my 2cents, and you can tell me to keep my nose short, but since you have a developer and plug-in forum, you could make a thread with all the plug-ins, and sticky it to the top so that it is always visible. That way no extra page to make.
[Aug 29, 2010, 7:53:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
db4tech
Download added! (End of first post) smile
Please let me know if there are any problems.
Enjoy! smile
db4tech
[Aug 31, 2010, 9:31:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
fhoofman
please view my small trial render, and you'll see a white spots around the image
is that normal or there's something wrong with the plugin
[Aug 31, 2010, 4:27:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
fhoofman
fyi, I choose option rendering silk and then white spot happen.
when I choose gloosy, it's just normal, nothing error
[Aug 31, 2010, 4:37:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hampi
thank you, this match perfekt on my sub-notebook
[Aug 31, 2010, 5:27:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
