Total posts in this thread: 12
Previous Thread This topic has been viewed 40427 times and has 11 replies Next Thread
white0demon
biggrin new plugin ready to use - duplicate style plugin
I have created the duplicate style plug-in
https://sourceforge.net/tracker/?func=detail&...d=152568&atid=1127349
If you have any suggestions or if there are any bugs please let me know
[Sep 5, 2010, 3:53:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
fhoofman
Re: new plugin ready to use - duplicate style plugin
what does it do?
and how to activate it?
[Sep 5, 2010, 6:34:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
white0demon
This is how to use it:
http://www.sweethome3d.com/userGuide.jsp
It's right in the end of the page.
As the description says in the link in my previous post, it copies the colour or texture you have set to an item to other items you have selected. For example it can copy the texture of the sink to the bathtub and the toilet.
Let me know if it doesn't cover your questions smile
[Sep 5, 2010, 8:21:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
fhoofman
ow, I see. what if I want to use the original colour / texture and then apply to the new item?
[Sep 6, 2010, 5:14:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
white0demon
What do you mean?
If I understand correctly you double click to the item and select the radio button "Default colors and textures" and then do the duplicate style process.
[Sep 6, 2010, 9:11:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As it modifies the selection, your plug-in should handle undo/redo too with the UndoableEditSupport object returned by getUndoableEditSupport. Look at other plug-ins or at PlanController class for many examples.
[Sep 15, 2010, 4:07:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
white0demon
I added version 3 with undo and redo included :)
[Sep 15, 2010, 8:11:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maker
Works very well, thanks. I wonder if it could be extended to "reverse" right and left face colours.
That way it can be used as a fast way to give all "inner" walls of a room one colour. Or for giving a brick texture to all outer walls of a house -- and the inside coloured.
Thanks.
[Sep 16, 2010, 1:21:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maker, isn't the Plan > Reverse walls direction menu item enough?
[Sep 18, 2010, 10:00:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maker
Not for me biggrin (on Win XP Pro)
Does it work that way in Linux/Mac?
[Sep 18, 2010, 1:56:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
