Total posts in this thread: 4
Previous Thread This topic has been viewed 2845 times and has 3 replies Next Thread
macfrog
Germany
different shapes of lights?
the lightbulbs are good. but how do i create other light objects, lets say a cube as a light or any other with a rectangular face?
e.g. for adding a LED strip light or making TV-screens shine bright?
also, ive tried to change an tv object (using artofillusion) to have a specific texture to represent a bright (light) picture, but sh3d refuses to show this tv object the same way, in fact, the texture is not even seen. why is that? how do i make a tv (or anything else) glow? flat glow if possible?
thanx
[Nov 14, 2010, 8:16:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PtiNounours
Re: different shapes of lights?
Hello Macfrog,
I'm a French user and I ask myself the same question
Maybe by placing a semi-transparent texture corresponding to the image broadcast by the TV and put a light behind. But it becomes difficult on a flat TV.
PtiNounours
[Nov 14, 2010, 10:35:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PtiNounours, your workaround is a good idea, but you're right, there won't be enough room in a flat TV to put a light behind the image! Maybe, it's worth giving a try with a matrix of 9 small lights for example???
[Nov 15, 2010, 5:00:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
macfrog
Germany
thanks for your answer,
i'm currently using one blue light bulb just in front of that tv. that will produce the nice dark blue mood i expect to see on a rendering with a tv in it :) but a "glowing" texture would be even better... is it not possible (yet) in general or do i have to do something special with that object for not messing the wanted the effect ?
frank
[Nov 15, 2010, 8:02:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
